Question about Tascam 122MKIII Single Dual Cassette Deck
Azimuth Adjustment on Tascam 122MKIII Cassette Deck
I am trying to adjust the azimuth on a Tascam 122MKIII Cassette Deck and I cannot figure out how to do it. I bought a really thin 00x2 1/2 philips screwdriver that still won't fit in the slot that appears to be the place to adjust the azimuth. I even started to take off the face and I still can't get to the screws.
Thanks.
  • 1,512 Answers
The screws are sometimes locked with Loctite or similer and the screw slot may be blocked up also. wetting the screw head with acetone will help to allow for the blocked screw head to soften. BE CAREFUL WITH ACETONE. it will damage plastic!!
Posted on Dec 09, 2007
  • 167 Answers
You must find a screwdriver that will fit. a jewelers tool kit may do it. you can break the screws loose without acetone,if the driver fits the screw.otherwise remove the door cover if you can, most slide upwards 2 unlock.hope this helps.
Posted on Mar 03, 2009
SOURCE:
Tascam 238 recording deck won't stop rewinding.
Well which is it 122 mk III or the 238?
The grease in the 122 will harden with time and gear crack or lose teeth. The deck needs to be worked on. There is myself in Chicago,
Russ in New Jersey that are still working Teac Technicians. There is Adrian in CA but I am not sure he wants to work on cassette decks.
Jun 08, 2014 | Tascam 122MKIII Single Dual Cassette Deck
The azimuth adjustment keys don't work
Send it back along with the hand controller describing the problem. Could be several things including a bad hand controller. If there is a local astronomy shop nearby take the scope there and ask to try one of the hand controllers in the shop and test it. If it now works you just need to buy another hand controller.
Otherwise send it in for repair
Jul 01, 2009 | Celestron NexStar 5 SE (300 x 44.45mm)...
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Azimuth Head adjust
IT IS THE ***** IN SIDE OF HEAD ASSEMBLY BRING A SMALL SIZE SCEWDRIVER AND MAKE FINE ADJUSTEMENT UNTIL YOU GET BEST SOUND LEVEL
Feb 23, 2008 | Audio Players & Recorders
Need a tec to repair
I can help you if you are in Queensland Australia. :)
Jan 19, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Tascam 122MKIII Single Dual Cassette Deck Logo
708 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
