Question about HP Photosmart C3180 All-In-One InkJet Printer
HP C3180 all in one printer won't realign
I have an hp printer and the paper jammed. After removing the jam, the cartriges stay to the left of the printer and won't allow anyone to print anymore. The check paper/check print cartridge light flashes and when you push it, it clicks and pops and won't go away from the left side of the printer. What do I do?
  • vzatek Dec 06, 2007
    the printer.
    Novelist:
  • 103 Answers
We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
Best regards,
Rosener Guyano
Posted on Feb 05, 2008
SOURCE:
HP 7310 Cartrige Belt Repair
The right end is connected with an idle pulley on a spring. If you grab the left end and pull it to the left, the spring will strech. This will help to attach the belt to the carriage motor on the left.
In some printers the spring streching is fixed by screw that have to be loosen first.
If you can't reach the motor's weel on the left, you have to take off some parts first.
Aug 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Paper stuck and can't reach from regular opening.
support site for that model http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=1146331
heres a link to paper jams - about half way down is a video of how to clear paper jams, and past the video is a step by step guide http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1146331
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | HP Photosmart C3180 All-In-One InkJet...
Hp photosmart 7760 print cartrige cradle is stuck.this happened after i ripped a paper jam out
try to move the cartrige cradle to left and right for about 10 to 11 times. if the issue still persist you may need to service you printer
Sep 27, 2009 | HP PhotoSmart 7760 InkJet Printer
Jammed paper
at the back thee is a litte door thing74e2861.jpg see where pen is - you pull the bit sticking up towards the usb and power inlets
hope this helps
Apr 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
C3180 keeps jamming
Many times you can remove jammed paper from rear area of printer.
Mar 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
Paper Jam in my all in one printer-scanner-copier HP PSC 2355
open the cover at the back of the printer that is provided to remove paper jam.remove the jammed paper and then off the printer turn it on again after few minutes and let in come to ready mode .it will take some time to come to ready mode as it will need to realign itself in proper position. once its in ready mode u can continue with ur work
Dec 17, 2008 | HP Office Equipment & Supplies
Paper jam
well..you may need to remove the software, and re install it...
and also, unplug the printer for around 5 min
May 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper Jam!!!
hi,
try this...
> unplug the power chord from the printer.
> open the rear access door.
> you will get full access to the rollers.
> remove the jammed paper gently.
> clean the rollers using a lint free cloth.
> close the rear access door.
> try to make a copy.
thats it.... if still u have the problem... contact me
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
434 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
