Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Sound & display problem on toshiba lcd 32hl95
Cable feed thru a cable box - - some channels exhibit breakup - - - - some channels, showing the same broadcast, are fine
    Problem Solver:
  • 11 Answers
Could be that the signal is not strong enough from your cabel company, just give them a call and they can come out and check. let me know if that is it.
Posted on Jan 21, 2009
SOURCE:
Add channels
Because thats all your TV can see is the feed out the cable box displays which in the US is channel 3. All cable companies encrypt their channels now so you have to have a cable box on every tv
Oct 19, 2014 | Televison & Video
Good sound no picture
Check whether you have pressed the TV/AV button on the remote control.
Apr 03, 2013 | Toshiba 37HL67 37 in. LCD HDTV
I just acquired a Toshiba 32HL95 TV and cannot get any hd channels although I have a digital cable box. I have tried using the coaxial, hdmi and video connections to no avail.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
Oct 23, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
It does not work on over the air tv
Do you have a digital converter box hooked up before it goes to the tv? USA is now digital and you need a converter box.
Thank you,
Lee
Feb 02, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
I just upgraded my cable box to a hd box and noticed that when i change channels, some hd channels either freeze or it takes a while for it to appear,, my cable company says it is a tv problem.. Is that...
It is definatly not your tv it the time it takes for the channel digitaly to hit the satillite and if there is interfarence it will breakup alittle or freeze.
Nov 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
May 30, 2009 | Toshiba 61A61 61" Rear Projection...
Changing TV set up to cable from "air"
Try setting tv to channel 3 or channel 4, this should coincide with the back of satellite box (a little black switch with a 3 or 4). then switch channels with your satellite box. I would recommend using another output off the satellite box to feed the other tv, a splitter loses some signal quality an can go bad as well. get a long rca cable to feed tv!
Mar 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No sound on digital channels
Reset the unit . Switch off, pull the power plug of the wall receptacle and wait for about 1 min. Then plug it back in and problem will resolve. Check if you have the latest version of firmware
Nov 25, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
35 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
