Question about AOpen FM56PX PCI Modem W/Vocie (MOAO18006PX)
AOpen FM56PXVV PCI MODEM (Net on hold Problem)
I installed the Net on hold program on to my system but when a call comes in the program will not let me accept the incoming call. I am running xp home for an os.
Thanks in advance
0 characters
1 Points
Can't connect internet. message reads error 633,
Here is a tip to work normally your modem, transfer it to another PCI Slots in the Motherboard and install again with the driver freeware provided. See to it that no other programs run on the system that interrupt your modem installation and diagnose it.
Please rate me.
Thank you.
Sep 15, 2009 | HP BCM5705 Modem
My AOpen modem fm56-svv say: NO CARRIER
Assuming you have checked the connection to actually make sure you have dial-tone, you could go into the modem's properties page (Control Panel -> Modems-> Properties) then go into the MODEM tab and make sure to UN-check the box that says "Wait for dial-tone before connecting". Sometime the modems don't detect dial-tone properly.
Sep 03, 2009 | AOpen FM56PX PCI Modem W/Vocie...
Code 10 problem showing in on modem(device manager)
that is a problem with your DIAL-up modem which is the old style, use your phone and dialin type of internet connection. so basically if you're on high speed you dont really need it, you can right click and disable. if the modem is in a desktop in a pci slot, you can actually just remove it all together. code 10 means the device wont start either due to hardware failure or bad drivers...but again, its a dialup modem and oyu're on highspeed so you dont even need it.
Apr 26, 2009 | Arris SM56 (SM-56-PCI) Modem
I cant find support for my AOpen modem
Have you tried manually installing a generic 56k modem driver?
If this does not work you will have to get a different modem that has support for Vista, as the Aopen website only has XP drivers.
Apr 22, 2009 | AOpen FM56 SVV (91.AC001.281) Modem
Software for motorola sm56 speakerphone modem
Hi... you can download the driver for that modem from this link:,sh,17715,319,16,.html
Click on run or save it depends if you want to have it saved or just run it. Hope this helps!
Feb 02, 2008 | Arris SM56 (SM-56-PCI) Modem
PC does not find modem
Remove the modem from the pci slot, uninstall the drivers you installed, shut down your system. now place the modem correctly in the pci slot( you can use the other pci slots also). strat the system with the driver cd in the cd drive. after logging in windows will display found new hardware screen, select yes this time only, on the next screen select automatically search for drivers, windows will search for the drivers automatically and install it if you are prompted to install a driver not signed by windows click continue installation. In case windows does not find the necessary driver, dont close the window or press the finish button, instead press the back button and come to the screen were you selected "automatically search for drivers, select manually search for drivers, and on the next screen click the browse button, navigate to the cd drive and select the correct driver inf file for the, you will have different inf's for different OS's, so select the correct os driver inf and proceed with installation, windows might say that the driver is not correct, you can still install it and give it a try.
good luck
Kindly POST back with your results
Jan 06, 2008 | Conexant Rockwell Modem
Modems Logo
61 people viewed this question
Top AOpen Modems Experts
Brian Sullivan
Brian Sullivan
Are you an AOpen Modem Expert? Answer questions, earn points and help others
