Question about LG WM2077CW Laundry XL Front Load Stackable Washer
Lg wm2077cw we have water coming out from where the soap dispenser is.  I can't see anything plugging it but I can't get anything to bend around the bend in the hose to see if anything is blocking it further on.  The water does drain but not fast enough.  Also, it has a slight leak at the bottom of the door seal.  Any help would be appreciated.
    New Friend:
  • 60 Answers
There is a valve at the end of that bent hose you mentioned which could be stuck or jammed up with soap. You'll have to take the top off to get to it. Be sure and clean the bottom of the glass on the inside of the door. A single piece of hair can allow water to seep out.
Posted on Dec 20, 2007
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
My washer is flooding water out of the soap dispenser and not going into the tub where the clothes are
Washing machines, whether top load or front load types, have a tendency to build up back pressure through the soap dispenser if the pipe/chute is clogged due to soap build-up being present. Check that the pipe/chute that conveys the soap and water to the drum is not clogged.
Aug 23, 2015 | LG Washing Machines
Lg. amt of water in soap dispenser after each wash.
Could be floor leveling ..Adjust and try
Oct 03, 2009 | Washing Machines
Water is pouring out of where the soap dispenser is. Can anyone help?
its pouring out because the dispenser is getting clogged in somewhere and not letting the water to the drain pump so its pouring from the soap dispenser. Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly , open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Jul 09, 2009 | Kenmore 43142 Front Load Washer
Lg wahing machine WM2077CW a little bit of water enters cycle slowly, and i don't see soap nor water
Hi, Turn the faucets off at the wall and remove the inlet hoses. Look inside the inlet valve and see if the screens inside the valve are plugged.
I hope this helps
May 30, 2009 | Washing Machines
Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
May 23, 2009 | LG WM1814CW Front Load Washer
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Soap dispenser slow leak
Plug off the wall socket first. Remove screws to remove the top of your machine. Check to see if the rubber hoses are connected well to the dispenser chamber, if not connect them properly. Another thing could be your dispenser drawer; you could pull it out gently to clean it; or you could even use a tooth brush for access.
Sep 20, 2007 | LG WD-1080FD Front Load Washer
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
230 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
