Question about RCA DRC8030N
Drc8030n says hello
The display just says hello and will not do any thing
  • 8 more comments
  • tsrca Dec 06, 2007
    I have the same problem. What do i do ???
  • Ewreck Dec 13, 2007
    Just keeps saying "hello"
  • cmossy Dec 16, 2007
    i have the same problem says hello but want get an on screen display,no way to operate unite without display. cmossy
  • spl0701 Jan 28, 2008
    I have the same problem, have either of these solutions worked for anyone??
  • ittybitsmom Feb 15, 2008
    mine is doing the same thing and it has a dvd in the player that I can't even get out. My two toddlera do not understand that their favorite dvd is stuck. I need help fast.
  • ynotte Apr 14, 2008
    Recorded on the hard drive then wrote or"copyed" to a DVD-RW. Cannot play th disk on any other player. Why?
  • Anonymous Apr 26, 2008
    BREIFLY HAD MENU FOR 10 MINUTES WITHOUT A DISPLAY, THEN WENT TO CONSTANT HELLO, HELLO, HELLO
  • oesc_amr May 06, 2008
    My wife just told me that she was listening some music and sudenly it went to HELLO, HELLO, HELLO, HELLO,
  • JJHOTLINE1 May 16, 2008
    MY RCA DVR JUST SAYS HELLO AND THA'S IT
    ANYWAY TO FIX THIS PROBLEM
  • stumpyn27 Aug 09, 2008
    my RCA DRC8030N just says hello and the tv screen just flashes the purple screen then to unusable signal. How do I fix it? This is new to me.
I also have the 'Hello' problem. Had a disc stuck, but you can remove the case screws and get that out. Looks like this DVR is faulty for everyone. I don't recommend it. I'm looking for a different one.
Posted on Sep 19, 2008
Do you mean the disk drive or the hard drive?
Posted on Aug 14, 2008
I have the same problem. Keeps displaying Hello. Will try to replace the DVR recordable drive. Any specific model?
Posted on Jun 21, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
That is right, you need to replace the DVD drive with a PC spare.
Posted on Jun 12, 2008
I just fixed mine I replaced the dvd/rw drive I guess the regular one is bad and the reason it will not work is that the IDE line is not working due to the drive not working so it just sits there..
Posted on Mar 25, 2008
Press the up or down Channel button. It will change the output mode to the RF which is probably the way you have it connected.
Posted on Dec 25, 2007
  • 83 Answers
Are all the cords connected? Is there any disk in? Make sure theese are all done
Posted on Nov 29, 2007
3 Suggested Answers
GSAN
  • 106 Answers
SOURCE: constant hello's
Constant hello is most likely the DVD drive. if you have a spare, then I would recommend replacing it (it is a computer drive so any will work). If you do not have a spare, then you can go to Ebay or Ecrater and purchase a used DVD drive and pop it in. It is failry easy to do.
  • 2427 Answers
SOURCE: RCA DRC8030N Problem
hey maybe you can try this first before the other solution posted i just read..
Open it up and unjack the drive unit from the maid board. it hould be connected via a cable.. turn the unit on and it should display an error message or error code.. Once this is done unplug the unit and reconnect the cable this should reset the unit and it should work..
I have never tried anoter drive before in any unit cause i could never get it to work, i always purchased the exact replacement parts.. In your case i believe its cause the main controller is damaged or frozen.. If you got a battery n the board remove it wiat a few minutes and replace it this should reset the unit..
Posted on Jul 09, 2008
Multi region code
1. Go to the main manu.
2. Open the Tray.
3. Press OK on setup.
4. Hightlight disk options
5. Press 8 2 1 3 x where x is the region you wish to use. Use 9 for all regions.
If you typed 8 2 1 3 9 it will quickly say region 9 on the display.
Mar 27, 2009 | RCA DRC8030N
Larger Hard Drive in DRC8030N
Yes you can replace the hard drive with a larger one. I have a 500 gig hard drive in mine. You can do the same thing with the DVD drive.
Any more problems, contact me at bigsteve1962@excite.com
Feb 26, 2009 | RCA DRC8030N
Rca drc8030n
the DVD Drive is bad. Replace it with the same (which I haven't been able to find anywhere on the internet) or one off the shelf (a little jerry-rigging is involved) and it will work. Everything else should be fine. This exact same thing happened to me.
Jan 14, 2009 | RCA DRC8030N
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Drc8030n Motherboard
Thank you so much for sending me those parts, and an extra thanks for the extras. Which happens to be what I needed to fix my problem. You won't believe it... I got your well-packaged parts today. I soon replaced the Motherboard, no change, still the same HELLO... I was so deceived... Then, I decided to replace the Power Supply, just in case... IT WORKED!... (thanks for sending me a free power supply)... Looking at my power supply, I can see that on the printed circuit under those 3 diodes, near the transformer, is an area that seems to have overheated. I will test it and give you the results eventually, as well as the results and solution if I can fix the DVD burner. I'll use the extra fan you so generously gave me to cool the power supply, seems like it won't hurt. Though I have to place it right, or it'll make the problem worse... Seems like anything wrong with this DVR and all it'll do is display HELLO... I've heard of a bad DVD Burner, a bad Motherboard and now a bad Power Supply that causes the HELLO... Thank you so very much GSAN, you did it... I recommend you to everyone out there for your fairness, kindness and devotion. We should call you Mr. FixYa!...
Nov 01, 2008 | RCA DRC8030N
Rca drc8030n hello
9 out of 10 the Hello problem lies in the DVD-RW board (I replace this board to correct the problem) and that 1 out of 10 time the problem lies in the main board that the IDEs connect to. I have replaced this board as well to correct such problem. I understand that these spare parts are impossible to come by. If you can make sure that the DVD-RW is fine by hooking it up to your PC and reading from it, then I can send you an RCA DRC8030N with the Hello issue that originates in the DVD-RW (so you can swap out the main board that connects the IDEs) and still have extra parts for later possible problems. If interested, you can contact me via triple w.suncitybargains.ecrater.com Thanks.
Jul 25, 2008 | RCA DRC8030N
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
Manual
my drc8030n only say "hello"
May 03, 2008 | RCA DRC8030N
Constant hello's
Apr 26, 2008 | RCA DRC8030N
Says hello
This is the power on procedure. Once it goes out, then press the poer button. If all you get is a blue screen, then turn off the progressive scan by pressing the small round button on the remote that is labeled "video out"
Apr 19, 2008 | RCA DRC8030N
RCA DRC8030N Logo
655 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
