Question about GE JE1860 Microwave Oven
GE JE1860 microwave won't turn off sometimes
Three year old GE JE1860 microwave that has recently started to not turn off intermittently. When it does this, you can open the door and it still "hums", though the turntable quits turning. Shut the door and it continues, and appears to be cooking when the door is closed because it burnt some kernels of corn that had been spilled in there. Opening and closing the door doesn't stop it, pressing cancel doesn't stop it, and we usually just try various things on the control panel until it shuts off. Seems once we can get it to start making the "normal" noises and the turntable turning, it will then shut off. I've tried unplugging it when it is doing this, leaving it unplugged for 10 minutes, and when I plugged it back in, it still did the same thing. It probably does this one out of ten times we use it, but there is no pattern.
HELP! Thanks in advance for any suggestions.
  • sarabannous Feb 13, 2009
    I have the same problem, fan and light won't turn off. Any help
  • GE Master
  • 9,098 Answers
You probably have a sticking relay on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details of our service, plus *critical* safety, disassembly, and troubleshooting info at our site.
You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
It is possible that you might have a bad door switch but I don't think so. In case you or a friend want to check that first, here are some links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
Wont turn on and no display showing no light on inside. Its plugged in and circut breaker has been checked. 8 Years old
It may be either the line fuse or the magnetron's thermostat.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting, testing, and locating components.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Aug 18, 2010 | GE JE1860 Microwave Oven
How do I replace the magnetron in my GE JE1860?
Considering the cost to have the microwave repaired: both labor and parts, it is more economical to purchase a new one unless it is still under warranty.
Jan 01, 2009 | GE JE1860 Microwave Oven
Microwave not working
faulty relay or solder joint on the power module, but a bad door switch is most common.
Nov 13, 2008 | GE JE1860 Microwave Oven
GE # JE 1860WH AH900849 not heating
hi Kathrine,
It sounds like the magnetron may be bad, if this is the case it may still be under warranty. Check to see if it's in warranty if it is contact GE or the store you bought it from. If it is I would not recommend you repair yourself (very dangerous voltage, and a very expensive part)
Mar 21, 2008 | GE JE1860 Microwave Oven
JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Mar 05, 2008 | GE JVM2050 Microwave Oven
Power surge
The high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. The magnatron is only affordable to do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 10, 2008 | GE JE1860 Microwave Oven
GE JE1860 Microwave Oven Logo
2,271 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
