Question about HP Pavilion F1703 17" LCD Monitor
The OSD Main Menu button keeps popping up every 5 seconds and whenever I exit it always takes me back. I've searched everywhere and found no solution just more people with the same problem so if I actually got some help it would be a dream come true.
  • 3 more comments
  • jabberjawsue Dec 10, 2007
    osd main menu button keeps popping up
  • noob232 Dec 28, 2007
    My OSD menu pops up at random times, my power button on my monitor chooses not to work at random times..., anyone got a solution?
  • adcain Dec 28, 2007
    The OSD Main Menu screen keeps popping up at random times and at times it won't go away at all. I am in business for myself and this is a reall nagging problem. Went to HP troubleshooting website for this monitor but cannot find a fix for this problem. Can someone please help. Do I nedd to buy a new monitor?
  • maxfactor999 Apr 29, 2008
    my osd ,ain menu keeps popping up...dont know what to do?????????
  • KatKellar May 08, 2008
    Problem with HP Pavilion f1503 / f1703 monitor -- Two boxes keep popping up randomly on my monitor screen: -- blue box that is used to set brightness and contrast and behind it I can see blue OSD Main Menu box. -- They come when they want and go when they want. The boxes appear over everything else on the screen, so I have to stop working on whatever I am doing until they decide to go away. My mouse pointer goes behind these boxes, so I can't use the mouse to make any selections on the boxes or exit them. Pushing in the menu button at the bottom of the monitor does not work either. HP technician told me to reset to factory settings but this did not work.
    New Friend:
F1703 monitor >> too simple!!! Unclip the front cover that sits around the front screen. >Becareful not to break the clips.>Remove the adjustment 715L1009-1-B (MANNEQUIN KEY BOARD) it has 2 screws and unclips from opposite side of the board. >> Clip back the surrounding cover.
Job done, no more OSD MAIN MENU ON YOUR SCREEN.
And you do not need to replace the board, your monitor will work just fine.
Posted on Apr 15, 2010
    Problem Solver:
  • 9 Answers
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
    New Friend:
I was also facing same kind of problem ... actually all my screen setting changing automatically ....I had tried many ways like cleaning with spirit ,heating etc. but all proved to me a temporary solution FINALLY I REMOVED MY SWITCH PANEL & BROKE ALL MY SWITCHES & NOW THERE IS NO PROBLEM I AM CHANGING MY SCREEN SETTING WITH THE HELP OF A SCREW DRIVER BY CLOSING THE CONTACTS OF SWITCHES>>.......
Posted on May 17, 2010
    Champion:
  • 220 Answers
Could be defective front panel,switches corroded or the Interface board could be defective.
Posted on Feb 17, 2008
I'v got the same problem yesterday .I spray with switch cleaning lubricant the 4 buttons of "Mannequin Key Board" and bye,bye problems. This happens when cleaning products is going through holes of facia, specialty spray solution
Posted on Aug 06, 2008
  • 3 Answers
Osd and main menu keep poping up
Posted on Feb 22, 2009
    Problem Solver:
  • 3 Answers
What I did to my Mitsubishi RD1714VM is I remove the cover and just resolder the tact switch on the front panel. After that the OSD didn't pop up anymore. I hope this helps.
Posted on Mar 26, 2013
  • Randy Navarrete
    Randy Navarrete Mar 26, 2013
    New Friend:
I have 14" dell Lcd monitor - the problem was the OSD screen offen 5 seconds appears, i could not work at all,so please give solution to avoid offen appearance of OSD screed
Posted on Oct 21, 2012
    New Friend:
    Problem Solver:
  • 5 Answers
Pls check 2 items-
1. The battery in the CPU mother board. Replace it if too old.
2. Unplug yr memory card from the slot & plug it back again. It could be loose.
Posted on Nov 19, 2009
SOURCE:
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
OSD Locks Automatically
hope this helps
Jun 07, 2012 | HP Computers & Internet
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
Osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Mar 28, 2009 | Philips 170S7FS 17" LCD Monitor
Monitor
You can lock or unlock the OSD by pushing the Menu button for over 15 seconds.
More info can be found HERE
Sep 13, 2008 | Philips 170B4MG 17" LCD Monitor
Help with my 190S monitor
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - [email protected]
Thanks
Aug 22, 2008 | Computers & Internet
Problem in TFT
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Problem on hp monitor
I know you said there were others that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
Oct 12, 2007 | HP Pavilion F1523 15" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
9,635 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
