Question about MicroBoards PF-2 InkJet Printer
Disc Feeding Problem
The discs on my printer feed at the start of a run, when the printer is first turned on, after about printing 3 to 4 discs, i keep getting an out of paper message and the printer will not feed any more disc, even if they are loaded, if i cause a disc to load manually the printer prints but will not feed any more discs.
  • 1 more comment
  • Bigfoot002 Apr 04, 2008
    I am using microboards ink cartridges but the discs on my printer feed at the start of a run, when the printer is first turned on, after about printing 3 to 4 discs, and the printer will not feed any more disc, even if they are loaded, if i cause a disc to load manually the printer prints but will not feed any more discs.
  • somerain May 11, 2010
    I've tried peel and sticking the label on a 78, but without any luck. Is there a trick to it?
    I've tried peel and sticking the label on a 78, but without any luck. Is there a trickClick here to post a Clarification Request to it?
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
Posted on Dec 22, 2007
SOURCE:
My Brother MFC 210C Printer, Copier, Scanner isn't feeding the paper.How do I fix this?
Use a water dampened cloth to clean the pickup roller. They get residue on them over time that causes them to not grip the surface of the paper when feeding.
Feb 06, 2015 | Brother Office Equipment & Supplies
DISC STOP FEEDING AUTO TO PF-2 PRINTER MICROBOARDS PRINT FACTORY..
Most likely the gravity fed disc cingulator needs to be replaced. My company can replace that Microboards Printer part for you. Call 952.944.0083 or visit.
Jan 24, 2011 | MicroBoards PF-2 InkJet Printer
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Loud irregular noise from printer during and after printing
This is the common problem of clp 300. you are required to change the black developer. for this you may approach authorised service center.
Dec 29, 2008 | Samsung CLP 300 Laser Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
DVd label
All document printers with disc printing capabilities suffer from disc feed problems. It is an inherent design flaw that results from the machines original design to print documents. Loading discs to be printed must first "go around" the printer's paper feeding mechanism to accept discs. I got tired of using document printers to print labels on discs. I switched to a DiscPainter made by Dymo. It is a dedicated disc printer that was designed as such from the outset and not as an afterthought. It prints every bit as well as any document/disc printer but without the frustrating mis feeds. Although the Canon printer is great for documents its design limitations for disc printing are not easily overcome.
Feb 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MicroBoards PF-2 InkJet Printer Logo
412 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
kevin gabrik
kevin gabrik
Level 1 Expert
Marvin
Marvin
Vladimir Frolov
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
