Question about Technics SL-BD22 Turntable
Installation of a Technics Turntable
My turntable has the audio outputs + a black wire. Whats the balck wire for? I can only hear the lp when I hook up to my CD recorder and put it in the record mode. I can't adjust the volume.
    Problem Solver:
  • 4 Answers
Isnt the black wire the ground/earth wire??
Posted on Nov 30, 2007
SOURCE:
I have a garrard turntable and I'm trying to hook
Connect the turntable wires into the recievers phono input and you should be good to go
May 16, 2011 | Technics SA-EX110 Receiver
Hi I have a Technics SL-350 Turntable System that I bought at a tag sale today. It turns on properly, spins, and you can even slightly hear the sound of the music while it's spinning. However, there is a...
plug a red and white rca cable into the back of the turntable and then plug the other end into your phono output at the back of the amplifier.then turn your selector on your amplifier to phono.wowla you should have sound
Oct 17, 2010 | Technics Audio Players & Recorders
I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Jan 06, 2010 | Denon AVR-689 Receiver
I PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE. I HOOKED THE RCA AUDIO JACKS TO THE AUDIO INPUT ON MY SONY TV AND GET VERY LOW SOUND LEVEL WHEN TV VOLUME CONTROL IS AT MAX. REPLACING CARTRIDGE AND...
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Oct 02, 2009 | Technics SL-BD22 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Turntable problem
It could be a couple of different things.
Do you get any sound, even very faint, if volume is turned up all the way?
If so, you probably have the turntable connected to the wrong type of input or you have the wrong type of turntable for the type of input you have on the receiver.
Older turntables have a very, very low level of audio output which requires an input that has much more gain than the normal type of audio input on a receiver.
Many newer turntables and receivers has the same level phono inputs and outputs as the other inputs and outputs of the receiver like the CD or Tape I/O. When an older turntable with such a low level output is connected to this type of phono input the sound is so low you can only hear it very faintly with the volume all the way up.
If you have the proper type of turntable for the type of input on your receiver, then the problem is most likely in the turntable. To check if it is or not, disconnect the turntable from the receiver, and then connect an RCA cable to the receivers phono input with nothing connected to the other end. Then with the volume turned up just about 1/4 to 1/2 the way up, touch the ends of the male ends of the RCA cable that are not connected to anything with your finger lightly tapping it a few times. You should be able to hear the tapping sound real easy in the speakers. If you hear that noise you know that the receiver is OK. If you don't hear anything the receiver has a pre-amp problem or the receiver is not set to the proper function.
If you determain the receiver is working normal, you have a problem in the turntable. Most times it is the stylus or the wires connected to the cartridge which holds the stylus.
Another thing to check is that if your turntable has a ground wire coming off the back of it near the RCA outputs of it, make sure that it is connected to the chassis of the receiver. Most receivers have a ground terminal right on the back that you can loosen with your fingers and then put the ground wire from the turntable in there and tighten it hand tight. If it has no ground terminal on the receiver you can always just loosen a screw on the back and connect it there. Make sure the ground wire has the insulation cut back to expose the bare metal, that insures that you have continuity from the ground of the turntable to the ground of the receiver.
If your turntable has no ground wire, then you have a newer turntable type that would be able to plug into any of the audio inputs on the back of the receiver. It would be a turntable with a boosted signal that can only be connected to an input with the same level as the CD or Tape input.
I hope this helps you to figure out what your problem is, if you need more help don't hesitate to reply to this post. I will get back to you as soon as I am able.
If this was helpful for you a "FixYa!" rating would be appropriate and very much appreciated, after all, it is the only reward we get for helping people like yourself for free.
Thanks,
Dave
Sep 06, 2008 | Yamaha RX-V995 Receiver
I lost Audio output Device No audio output when using turntable. Can hear sound with headphone, can hear sound when hooked directly to speaker. Can not get sound out of audio output. Plugged RCA cables...
turntable needs high sensitivity preamp. the output level is so low that it has to be amplified more. usual inputs of turntable are phono input. needs a high sensitive input to handle.hope this help.
Aug 08, 2008 | Kenwood KR-V7080 Receiver
Technics SL-DD33 Turntable
Well, it will play, it will just be very annoying to hear that humm. Unfortunately, you cannot get the wire plug from Technics, as it has been discontinued. So, the only other option is to take it to a service center, and have them 'hard-wire' a ground table to the unit. This entails opening it up and running a ground wire from the inside of the unit. Shouldn't cost you much, and should take about 30 min or so to complete. If you are quoted more the US$40, take it else where.
Any qualified electronics technician should be able to handle this. It's Audio Repair 101 - very easy stuff.
- OPTiC
DIGITAL ANALOG THERAPY
www.repairny.com
www.1200s.com
May 10, 2008 | Technics SL-BD22 Turntable
Technics SL-BD22 Turntable Logo
195 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
