Question about Whirlpool LSR5132PQ Top Load Washer
Leaking How do I remove the cover off my washer so I can figure out what is leaking?
  • 83 Answers
The head where timer is will lift up there might be 2 screws on each side.unplug lid switch, remove brackets on each side case will pull out toward you. You need to bypass lid switch with jumper wire to get unit to run without case.
Posted on Nov 30, 2007
I'm getting an E:17 error code on my washer when I try to start it. In January of 2012, eMCee2 provided an answer that apparently worked to someone else with this problem.problem. Problem is, I can't...
You have a leak
it is collecting in a tray under ther washer
the tray has a float switch in it
when the tray fills up the float switch activates telling the computer it has a leak ERROR CODE F17
by tipping the washer backward you drain the water in the tray and reset the switch
this will only be a short term fix because you still have a leak somewhere
Mar 29, 2015 | Bosch Vision Series WFVC6450UC
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
How can i get to the fuel pump on a 92 acura vigor?
  • REMOVAL & INSTALLATION
  • Print
    The fuel pump on all models except the 1986-90 Integra, is located in the fuel tank. On the 1986-90 Integra the fuel pump is located under the rear of the vehicle, near the drivers side of the fuel tank.
    PRESSURE TESTING
    See Figure 1
    On all models, the fuel pump should run for about 2 seconds when the ignition is first turned ON . By removing the filler cap and listening at the filler, it should be possible to hear the pump run each time the ignition is switched ON . It will then stop again until the starter is activated.
    Fig. Fig. 1: Checking the fuel system pressure
    1. Disconnect the negative battery cable and remove the fuel filler cap.
    2. Relieve the fuel system pressure.
    3. Remove the service bolt and attach a fuel pressure gauge to the top of the fuel filter.
    4. Start the engine and measure the fuel pressure with the engine idling and vacuum hose to the pressure regulator disconnected;
    1986-1989 Integra-35-41 psi. (240-279 kPa) 1990-93 Integra-37-44 psi. (255-304 kPa) 1989-90 Legend-36-41 psi. (250-279 kPa) 1991-93 Legend-38-46 psi. (265-314 kPa) Vigor-43-50 psi. (300-350 kPa)
    1. Check to see that the pressure decreases when the vacuum hose is connected.
    2. If the pressure is higher than specifications, check for a pinched or clogged fuel return hose or faulty pressure regulator.
    3. If the pressure is lower than specifications, check for a clogged filter, defective pressure regulator or leakage in the fuel line.
    4. After inspection, remove the pressure gauge and install the service bolt with a new washer.
    1986-1989 Integra
    1. Disconnect the negative battery cable.
    3. Raise and safely support the vehicle and remove the left rear wheel.
    4. Remove the fuel pump cover bolts and the cover.
    5. Remove the fuel pump mount bolts and the fuel pump with it's mount.
    6. Disconnect the fuel hoses and the electrical connectors.
    7. Installation is the reverse of removal. Use new sealing washers when connecting the fuel hoses. After the pump is installed, turn the ignition switch ON and OFF a number of times to pressurize the system and check for leaks.
    1990-93 Integra and Vigor
    See Figures 2 and 3
    1. On Integra, remove the rear seat and access panel and disconnect the wiring.
    2. Remove the fuel tank.
    3. Remove the pump flange mounting nuts and lift the pump out.
    4. Installation is the reverse of removal. Use new sealing washers when connecting the fuel hoses. After the pump is installed, turn the ignition switch ON and OFF a number of times to pressurize the system and check for leaks.
    Fig. Fig. 2: Removing the fuel pump access cover-Legend and Vigor
    Fig. Fig. 3: Removing the fuel pump assembly-Legend and Vigor
    Legend
    3. Remove the maintenance access cover in the luggage area.
    4. Disconnect the fuel lines and the electrical connectors.
    5. Remove the fuel pump from the fuel tank.
    6. Installation is the reverse of removal. Use new sealing washers when connecting the fuel hoses. After the pump is installed, turn the ignition switch ON and OFF a number of times to pressurize the system and check for leaks.
    Nov 09, 2012 | 1992 Acura Vigor
    Stackable washer (bottom), top load leaking water??
    Easy fix most likely the water pump is leaking or the hose from tub to pomp. Remove the front cover
    A couple of screws at the base come out and you can remove the front.
    Run is a while with the cover off to see where the leak originates but
    keep the pets and children away from the machine while the cover is off.
    Tip it back to remove the belts.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Feb 10, 2011 | Maytag LSE7806A Top Load Stacked...
    Could it be possible that water would be leaking from the bottom?
    There are several ways the water could be leaking, depending how old the washer is it could be leaking from the large rubber seals that are located in the front of the washer if it is front load or under if a top load. The best way to figure out where the leak is coming from is to get a visual from the inside. Unfortunately you have to remove one or two covers to get a good look. Usually you will see a stain residue from where the water could be leaking from.
    Aug 09, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    How to remove valve cover to replace valve cover gasket
    1C-LTC and 2CL-TC Engines
    (see Figures 1 and 2)
    1. Disconnect the negative battery cable. Remove and label all electrical wiring, connectors and vacuum hoses necessary to gain removal clearance.
    Fig. 1: Loosen and remove the cylinder head cover retaining nuts
    1. Disconnect the PCV hose.
    2. Remove the six nuts and seal washers from the cylinder head cover. Loosen them in a crisscross pattern.
    3. Remove the cylinder head cover and the cover gasket from the cylinder head. Discard the gasket and replace with a new one.
    To install:
    1. With a wire brush or gasket scraper, remove all the old gasket material from the cylinder head and the cylinder head cover gasket surfaces.
    2. When the cylinder head surfaces are free and clean, apply beads of sealant to the cylinder head in the locations shown in the accompanying illustration.
    Fig. 2: Be sure to apply sealant on the cylinder head prior to cover installation
    1. Install the new gasket in the cover. Make sure that the gasket seats evenly.
    2. Place the cover with the gasket onto the cylinder head.
    3. Install the six nuts and seal washers. Tighten the nuts to 65 inch lbs. (8 Nm).
    4. Connect the PCV hose. Connect all removed vacuum hoses, connectors and electrical wiring. Connect the negative battery cable.
    5. Start the engine and inspect for oil leaks. Repair any leaks as necessary.
    Hope this help (remember comment and rated this).
    Apr 16, 2010 | 1990 Toyota Camry
    I have a 1960s whirlpool washer that is leaking out of the bleach line. I was trying to figure out how to pull the drum out of the barrel.
    At this point in time it might be less distructive to go shopping for a new machine. To remove the inner basket you will have to remove the tub cover which will probably not seal after removal due to errosion of the tub. With the tub cover removed, remove the agitator which will uncover the next great feat, the hub nut which requires a special wrench to remove. If you can remove the hub nut after 40 years of corrosive detergent water you may be able to remove the inner basket if it isn't ceased on the drive block.
    Feb 27, 2010 | Washing Machines
    Leak
    bad pump..take some news paper and slide in from bottom you will notice that the drip is coming from the left side more,,..if you can get behind unit theres 2 green clips on the right and the left remove these,,if you cant get behind remove front panel ..and remove from front...slide lid forward than remove lid switch connection right front corner,,now the tops off...remove the 2 screws holding washer front panel..now your in ,,to put back reverse...att'' always unplug unit first
    Sep 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
    Water leak
    If the main seal is leaking there will typically be a splash line around the inside of your washer cabinet. There is a special wrench available for removing the large nut that holds the inner basket in. This nut is aluminum and can be removed with a chissel if it is stuck. remove the inner basket and you will see cone shaped "NUT" that is covered in cork. There is a torx screw on the side of the cone shaped piece. once the screw is removed then the cone shaped nut can be removed using the special wrench and brute force.
    Mar 10, 2007 | Maytag Legacy Series Top Load Washer
    Whirlpool LSR5132PQ Top Load Washer Logo
    35 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
