I'm getting a Machine Error 76 on a Brother MFC 9600. There was a crumpled paper jam inside the fuser unit. I took all the covers out just to remove the paper jam, connected all the connectors back on, including the connector on the fuser unit. Turned it back on and it comes up with the error. Need Help !!
How to cold reset a Brother MFC 9600? I went to www.fixyourprinter.com and it says "Open front cover, turn power on and press 1,2,3,4,5,6,7,8,9 and should reset it to factory settings". It didn't work. Need help!!!
Same problem: How do you do a RESET???
error 76 i don't know how to reset (brother 7600)
I have the same problem. By following little bits of advice (unplugged the machine, held function key while plugging it back in, then pressed 99) I was able to clear the error 76 message, only to get an error 78 message. Any advice?
My Brother MFC 9600 is showing an Error 76 fault. Tried turning the machine off and on but that didn't work. Other postings on the Internet suggest the Fuser Unit has failed. Can this be changed in house with out the need to take it to an Authorised Brother Service Center. Cheers> JB> New Zealand
I had a Machine Error 76 -
I followed what someone else said.
I unplugged the MFC9600.
I held down the function key and replugged the MFC9600, then hit 99.
Believe it or not, the MFC9600 now copies.
I hope this continues.
MDS84
jam inside message after replacing fuser unit
Clear Paper jam error
