Question about Brother Sewing Machines
Needle securing screw
I need the little screw that holds the needle in place for a brother PR-600II embroidery machine. Need very quicly
My PR600II error message main rotate error. what can i do to fix it
Posted on Dec 15, 2009
SOURCE:
How do I replace my twin needles on my brother overlock 1334 D ?
That is not a twin needle. It is actually two individual needles that are separate. (There are actually some stitches that you would use only one needle, ie hem.)
The manual will have instructions on how to replace the needles. There appears to a hex screw immediately above the needles that is used to remove or secure the needles. With the hex tool included with your machine, loosen that set screw (be careful because both needles will become loose and can drop down into the machine). Hold the needle(s) with the flat side facing the back of the machine, slip them all the way up in the needle holes, hold them in place while tightening the hex screw. Be Careful to not lose the hex screw that hold the needle or drop the screw or needle down into the machine.
User Guide Manuals 1334D Australia Brother
Nov 12, 2016 | Brother Sewing Machines
How do i repair X-Axis home position error for pr 600II
If the machine's embroidery arms have been moved under force when the machine's power is on, you may need to have the machine tune up and reset to true center. I would suggest taking it to a authorized repair shop for a good cleaning and service. In most cases for what you paid for the machine, there is included service that can come with the purchase of the machine, or in the least, a discount on mechanical services and repairs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Mar 02, 2015 | Sewing Machines
My button needle won't release the needle
I think you should consider a little oil if it's metal parts - it is a small spring that holds the needle in place
Aug 29, 2014 | Brother PE-770 Embroidery Machine
My pr 600 freezes
You might have Thread particles build up. Puchase canned Air for electronis and use it on a regular basic to clean your bobbin case area. Also when you change threads color always clip your thread near the spool and pull your thread out from the bottom near your needle. When you pull your thread through the top little pieces of the thread break of and fall into the chamber of your embroidery machine .
Mar 05, 2014 | Bernina Bernette Deco 600
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
I have a Disney Brother SE-27OD Embroidery Sewing Machine When I am doing the embroidery the needle comes out I put it in as tight as possible but it keeps happening from time to time.
Make sure you have the flat part of the needle to the back when putting it in and that it's (preferably) a Schmetz embroidery needle with the red band either 75 or 90 or a Schmetz universal 80. Make sure when you install it you can see the top of the needle in the needle slot and all the way up so it's hitting the post before you turn the screw tight. Check the screw each time you sew to make sure it hasn't shaken loose from embroidering.
Dec 13, 2009 | Brother SE-270D Computerized Sewing...
I am wanting a monogramming or embroidery machine for my home business. I am looking at a Meistergram 900xl. Does anyone know anything about this machine? I know they only make embroidery machines now so I...
I would recommend looking at the PR-620 its a single head emb only machine with 6 needles and is made by brother, you can do hats and just about every thing including momgramming plus they have a great rebate going on right now
Jul 15, 2009 | Brother CS6000i Computerized Sewing...
Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Jul 08, 2009 | Brother XL-6562 Mechanical Sewing Machine
Threading the needle of the embroidery machine
You may need a magnifying glass to see the tiny hook that should pass through the needle eye to catch the thread....
....if it is not aligned properly and does not go through the eye you will need to realign it....
...there may be a small screw attaching the mechanism, loosen slightly with jewelers screwdriver so you can move it but there is still some friction and gently engage the needle threader to see how far you need to move it, then gently, using a fine screwdriver, tweesers etc, nudge the tiny hook a little, check result and continue to adjust until remedied....re-tighten screw.
If there is no screw adjustment, a gentle bending will resolve the problem............but if there is no tiny hook, it will need replacing.
They are not easily broken, but only use gentle pressure to be sure.
May 22, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
134 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
