Question about E-Machines AC Adapter for eMachines M6410, M6412, M6414 Notebooks (ADEMAC) Power Supply
Emachines C2825 My machine does not start anymore, I took it with a repair guy and He tld me that is th epower supply and probably the motherboard as well. Does it is better to buy another used cimputer for around $ 100.oo usd than try to fix mine?
    Master:
    Sergeant:
  • 482 Answers
You can go to ebay and put in the power box numbers and the mother board numbers and you can replace them for less the a $100
Posted on Dec 03, 2007
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Emachines w3507 power
detarch all accessories or hardware connected to the system , then bring out the power pack itself out completely look for a soldering led to test the functionality of the power pack itself if it rotates the fan of its pack by looping the first hole to the third hole cable in the power pack connector that will head into the motherboard. therefore, check the mother board if there is any damage on it like some component if all this is false . then plug the power pack to the outlet and fix the connector of the power pack to the motherboard after detaching both cd drive , floopy disk drive leaving the hard disk and the memory . then change the memory card and press on the system there should be a solution from all this . the problem should be from the Memory not to be able to start up the system but go through those process i have given you before concluding it was the memory ok....
kindly rate this solution......
May 05, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I accidentally unplugged the wires to th epower buttton and need to know how to reconnect
If you do know which are the posts on the motherboard it does not matter which of the two wires goes to which post. typically, the Red goes to the post that is matked (either by a dab of paint or by the fact that the solder at its base is square rather than round.
If you do not know which are the right posts, then get a M/B schematic from emachines
Sep 22, 2009 | E-Machines eMachines Desktop PC
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
Emachine T3624 desktop PC won't turn on?
I can guarantee 100% you have a bad motherboard. I have seen this exact problem with hundreds of E-machine PC's (especially your particular model).
What happend is the power supply went bad and took the motherboard with it, e-machines use very cheap OEM powersupplys that do not have any fault protection to protect the motherboard from damage if the power supply gets a surge or other damage.
You should not waste your money repairing the hardware in this PC, i would buy a new PC and transfer the data over.
Jan 20, 2009 | E-Machines eMachines Desktop PC
Emachine 180 (bought 2004)
I have this type of computer (just sitting around , not for my main computer) and I had a smilar problem. I took it to a guy I know (who owns a computer repiar shop) an he said the motherboards on this model go haywire about four years after initial power-up. On mine, it caused the power supply to blow-up (literally) and blew out most components. (Floppy drive, Sound card, USB ports, Keyboar/mouse plugs)
I really don't know if What he said is true, but I replaced the power supply, and now it works fine.
Jul 16, 2008 | E-Machines eMachines Refurbished EMA...
Emachine power supply
Unfortunately, E-Machines are well known for their power supply problems. I have a room full of them.
Let me guess, you can hear something rattling around in the power supply, right?
When this happens, a component blows cleanly off of the board inside, and sends a voltage spike to the mainboard.
With any luck, the hard drive logic board wasn't damage, and you can recover your data with another PC.
Apr 25, 2008 | E-Machines eMachines Desktop PC
Emachines C2825 problem
If you know the motherboard is bad as well, you have two options. You can salvage the existing case and parts, and replace the motherboard and PSU. Plan on spending around $100-150 for both together. This assumes the CPU and RAM are undamaged. The second option is to buy a different "bare-bones" system, and transplant the parts into that one (CD/DVD drive and Hard Drive). Unless you have an exact replacement for the motherboard, you'll probably need to reinstall Windows. The easiest way around this is to install Windows onto a new hard drive, and attach your old hard drive as a "slave" or "secondary". These two options are centered around off-the-shelf parts, rather than buying a "brand X" computer. If you prefer "brand X", which includes an 800 # you can call, look at Dell. eMachines and Dell both produce low-cost low-quality systems, but Dell is better at it. For ideas on parts, look at an online retailer like NewEgg. For compatability, this is mostly a matter of using a tape measure and/or counting pins; they have low prices because they aren't there to hold your hand; if you would feel more comfortable with some hand-holding, which is fine, buy a new "brand X" computer. Lastly, keep in mind, the difference between a $500 computer and a $1500 computer is more than profit margin. If they don't say exactly what a part is, it's whatever was cheapest at the time. A $500 computer may be all you need, but it will have problems like this; whether that's best for you, is for you to decide.
Oct 01, 2007 | Intel D845GVSR Motherboard
P4MBMS Motherboard Problem
look for the reset jumper on the board and then reset it then try again
Jun 03, 2007 | Mach Speed P4MBMS Motherboard
Computers & Internet Logo
159 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
