Question about Olevia LT23HVX 23 in. LCD Television
Cable question iam having problem getting my TV to work with my computer at a 1024 X 768 pixels, and iam using a VGA/SVGA premium cable for the cable connection. Is the cable type the right one , or is there another type of cable that will enable my TV to reconfigure the desired resolution???
  • 259 Answers
Make sure your refresh rate is set no more than 60HZ. Your monitor might not support refresh rates higher than that.Also try lower resolutions.
Here is a list of specs: (also try another cable)
Features/Specifications:
  • Olevia LT23HVX 23-inch HDTV Compatible Widescreen LCD TV
  • General Features:
  • Black cabinet
  • 23-inch active screen size
  • 16:9 widescreen aspect ratio
  • HDTV Compatible
  • 1366 x 768 native resolution
  • 1600:1 contrast ratio
  • 8 ms response time
  • 178° horizontal and vertical viewing angle
  • NTSC TV system support
  • 480i, 480p resolution support
  • Progressive scan
  • Color temperature adjustment
  • Built-in 5 watt x 2 speakers
  • PC resolution support up to 1024 x 768 @ 60Hz
  • English/French/Spanish language
  • Sleep Timer
  • V-Chip parental control
  • Energy Star compliant
  • Remote control included
  • Wall mountable
  • Front Panel Features:
  • IR sensor
  • Power
  • Menu
  • Channel down
  • Channel up
  • Volume +
  • Volume -
  • Source
  • Rear Panel Features:
  • 15-pin VGA
  • Audio in
  • Headphone
  • Component Y, Pb/Cb, Pr/Cr
  • Composite RCA video inputs
  • S-Video
  • Antenna
  • Power Specifications:
  • 100-240V, 50/60Hz, 2.5A (max)
  • 110 watts AC power consumption
  • Unit Dimensions:
  • 16.5 x 27.1 x 8.3-inches (H x W x D)
  • Gross Weight: 23 lbs
  • Net Weight: 21 lbs
  • Regulatory Approvals:
  • FCC
  • CSA
  • UL
Package Includes:
  • Quick Start Guide
  • Manual
  • Remote control w/two AA batteries
  • Power cord
Additional Information:
  • Notes
  • Model: LT23HVX
  • Product Requirements:
  • Satellite cable or antenna
  • PC with 15-pin VGA adapter
  • Stereo system with component, S-Video and composite jacks
  • Available power outlet
  • Disclosures:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 20-Inch to 23-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15mm (bright to bright dots)
  • Minimum distance between defects: 5mm (dark to dark dots)
  • Disclosures:
  • Consumer Notice:
  • This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation’s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission’s digital television website at: www.dtv.gov.
Posted on Nov 29, 2007
SOURCE:
Screen has a yellow tint that I have not been able to get rid of.
Try this instead
change out the connector in the back of the computer, or the monitor cable (Replacement cable *see below) While the connector/ cable is going out it can give a solid hue across the entire screen.
You can also try updating the video drive through device manager to see if an updated is need.
Hope that helps.
Fullink Premium Blue Connectors HD15 Male to Male SVGA VGA Long Video...
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Sep 27, 2015 | HP 2009M Monitor
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
My toshiba S300m has a VGA socket and no S cable socket. I want to connect the Tosh. with my TV. Problem is that the TV is an older one and has a S video (female) and it also has three (Yellow, white,...
try to lower your video/screen resolution down to what your older tv can take as an input. (try 800x600 or lower) first if that does not work search on eBay for
VGA SVGA TO S-Video 3 RCA Composite AV TV Out Converter Adapter Cable PC Cord
Jun 04, 2017 | Toshiba Satellite Pro S300M-S2403 Laptop
How to connect my pc to my tv & use it as a [email protected]
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
Samsung LN-T4661F will not display PC; displays 'mode not supported'. Using a VGA cable to connect laptop to tv
Look in the manual for the TV and determine which platform is supported. VGA, XVGA, SVGA etc. Set your computer output to the proper mode and the unit should work. Let me know how you make out.
hardrocko
Jan 31, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No picture
Try going into your display settings on your PC and reduce the resolution down to VGA or one higher and see what happens.......Let me know
Feb 03, 2009 | Toshiba Televison & Video
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Laptop connect to t.v. monitor problem
Did you verify the input on your tv?
There should be a source button on the side or bottom of your tv.
Click it until you see the VGA input.
I hope this helps you!
Sep 24, 2017 | Acer LCD 12 1 DSTN/SVGA Monitor
Televison & Video Logo
312 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
