Question about Epson Stylus C84 InkJet Printer
CAN NOT PRINT LWORKS FILE TO THE EPSON STYLUS C84 PRINTER
I want to print a file created with my Lworks program in the Epson Stylus C84 printer but can not print it..
I am using a Toshiba Laptop with Windows XP. Do I need a Epson printer driver in the Lworks program and if I need a priter driver, how do I download one? Please advise.
THANK YOU.
Harry
[email protected]
    Scholar:
  • 79 Answers
Can you print something with a different program such a Microsoft Word? If you can then the problem is with LWORKS if not then the problem is with the printer driver. Please respond so I can help more.
Thanks for reading!
Posted on May 01, 2008
SOURCE:
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Nov 12, 2009 | Epson Stylus C84 InkJet Printer
Printer wont print out in colour The inks are full. The black ink works but not the colour inks, Epson stylus C84
Epson Requires Original Epson Ink.
Colors will not come out as they should, and then the words will print out only either top or bottom.
Good Luck....
Oct 06, 2009 | Epson Stylus C84 InkJet Printer
I need control codes for an Epson Stylus C84 printer. I need to make it print with a smaller font.
Hi nosnilleb - are you talking here about basic escape sequencies for DOS, or HP PCL Emulation? I think you will find all you need if you simply do a Google search for it. This is really a software programming problem not really suitable for here.
Mar 04, 2009 | Epson Stylus C84 InkJet Printer
Not printing
If you've just bought a C84 today then you've been sold a second (or even third) hand unit which is clogged solid.
To resolve this you're going to need to clean the printheads which is something I've described here
It's a different printer but the same process applies.
Hope that helps.
Feb 21, 2009 | Epson Stylus C84 InkJet Printer
Stylus is not printing
It appears that gbmalabanan and guest have lost interest in this problem, so I think we may post it as "Solved by Posters".
Jan 18, 2009 | Epson Stylus C84 InkJet Printer
Epson Stylus C84
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The durabrite inks that EPSON invented is brilliant when you print pictures but it tends to harden very easily
Thanks for reading!
Mar 16, 2008 | Epson Stylus C84 InkJet Printer
Epson c84 ink cartrages
Hello Carla, can you manually clean the heads where the ink delivers the printer. Try using the printers own program first then do a manual clean with proper cleaning solution if this will not work.
Mar 10, 2008 | Epson Stylus C84 InkJet Printer
CAN NOT PRINT LWORKS FILES IN EPSON STYLUS C84 PRINTER
Hi there HarryW - what is the "LWorks" program? Is it a Windows program - if so, you don't need a separate driver for it. All you need to ensure is that the printer is properly installed on your Toshiba as a Windows printer. If it isn't installed, just insert your Epson C84 CD and follow the instructions.
If you don't have a CD, go to
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23953&prodoid=36033903&infoType=Downloads&platform=All
to download the driver (Printer Driver v5.4cA).
If Lworks is not a windows program, or if you have any further queries, report back to me with a new comment.
Please rate this solution if it has been helpful to you.
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
Printer not printing
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Epson Stylus C84 InkJet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
