Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag 2 speed replacement motor
(washer wires) (Replacement motor)
Green ---timer capacitor-------------- ??
Yellow--------------------------------------- Yellow
White --------------------------------------- White
Black --------------------------------------- Black
Brown Blue
Orange Red
The replacement motor only has 5 wires washer has 6. Where does Blue and Red goes? Where does Green (capasitor wire) go?
  • 45 Answers
You may have wrong part , post model serial , and part number that you have i will look them up
Posted on May 16, 2008
SOURCE:
My timer will not advance.
Normally that is a timer motor or motor gear and needs a new timer. Easy replacement, just unplug the washer, take the back off and replace one wire at a time from the old to the new. Then remove the old one and mount the new one. I had to replace mine a while back.
Mar 20, 2016 | Maytag Washing Machines
Tip
Maytag Neptune Front Load Washers Machine Control Board Repair
Component failures on Maytag Neptune Font Load Washers such as the pressure switch, wax motor, hot and cold water valve solenoids, timer motor, 24 VDC circuit, and the overall electrical buffer circuit have significant effect on the machine control board. Failed resistors on the machine control board can be used to determine failed washer components. Resistor R9 is associated with the pressure switch, R11 is for the wax motor, R51 for the hot water valve solenoid, R52 for the timer motor, R53 for the cold water valve solenoid, R143 for the 24 VDC circuit, and R162 for the overall electrical buffer circuit. The TRIAC Q6 is also associated with the wax motor while TRIACS Q3, Q9, and Q17 are for the timer motor, cold water valve solenoid, and hot water valve solenoid respectively. These TRIACS must also be replaced should the corresponding resistors fail or burn out especially when there's no power going to the associated component.
The most common problem experienced is the failure of the wax motor as indicated by the inability of the washer to advance to the high speed spin cycle with the "door locked" light not lit. Replace the TRIAC Q6 and the resistor R11 on the machine control board to get the machine back into operation. Use MAC97A6 or NTE5656 for Q6 and a 3.9 kilo-ohms carbon or carbon film resistor for R11. It is recommended to install a 1/2-ampere pico fuse in series with the wax motor to prevent damage to Q6 and R11 should the wax motor shorts out and fails again.
Replacement of the wax motor is a must before installing the repaired or new machine control board to prevent damage to the repaired or new part. Make sure the wiring harness connections of washer components are good and snug fit. Reseat the connectors several times to clean off corrosion build up both on the connectors and terminals.
on May 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer MAH4000AWW timer will not advance. Washer will operate if I manually advance timer. Have changed timer, followed Drive System diagnostic test, the wax motor and control board were replaced a...
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
Nov 08, 2013 | Maytag Washing Machines
Replaced an old Magnetek century two speed with a AO smith century two speed. Hooked the wires up the same but unable to get the motor to operate in the high speed mode, suggestions!
Each motor will have wiring diagram on label.
Compare diagram on old motor with new motor.
WIRE COLORS VARY
Which 2-speed timer do you have on the circuit?
Wire lead from NO terminal connects to High speed.
Wire lead from NC terminal connects to Low speed
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 23, 2012 | Pool & Spa
I have the maytag washer mav 7000 aww; The Timer does not work automatically but works when moved by hand to each function. This is a 120 volt 60Hz machine and since i stay in a country, where we...
Open the control console.
Use a voltmeter to test the timer motor.
Set the machine to wash.
Place the meter leads on the 2 timer motor wires.
If you read 120 volts and the timer does not advance,the timer motor is bad.
The complete timer will need replacing.
Sep 22, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Receiver quit. replacement has just one wire and a
all of the white wires connect together and to the white house wiring ... the black of the house wiring goes to the AC input of the module (may be a black wire ) .. the blue wire from the lights goes to the light output of the module (as you already know) ...
now the motor actually has only two wires .. one white that should already be hooked up with all the other white wires .. the other goes to a block that contains the speed controlling capacitors .. and that has the 4 wires (you metioned cominng from the motor) .. the capacitors are no longer needed since the speed control inside the module takes over .. so you can eliminate the capacitor block (thats normally connected to the speed control switch that you wont need either)... that will leave you with just one wire from the motor that has to be connected to the modules motor wire output ... that should do it ... set the code on the module and remote the same (in battery compartment of remote) (good idea to make sure your neighbor isnt using the same code ..
connect the green wire (or bare wire) to the metal of the fan ..usually a green screw or a bare wire .. thats the safety ground ..
May 27, 2010 | Hampton Bay 24002 Ceiling Fan
Kenmore Series 80 washer NO High Speed Spin
It could be a timer, motor or wiring problem. You would need to check for 110 volts at the timer or motor when in the higher spin mode. If you are getting 110v you have a bad motor. No or low volts you have a bad timer. The motor is either a 2 or 3 speed motor and you would have to determine which winding to check for the 110v. The schematic is usually glued to the inside rear cabinet. Please rate this post.
Dec 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I am replacing the a/c blower motor and capacitor. The old motor has 1 brown wire to the capacitor, 1 yellow wire to the capacitor (the yellow then loops from the capacitor over to the wiring panel), 1...
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Apr 27, 2009 | Heating & Cooling
Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
Jun 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
