No dail tone report
New dail up modem reports "no dail tone" message,line is good.Need to us just for faxes as have broadband for rest! Have tried before and after filter,assume it should be after ,dosnt make any difference it seems!
    Problem Solver:
  • 11 Answers
Some dial connections dont like the filters attached. does the new modem have more then one ethernet connection on it? have u tried it on another connection if u have on in the house? it may just be your settings in the computer. are you using the same computer for both broadband and dial up? if you are then you may need to adjust the settings in your computer, your isp should have done all that for you.
Posted on Dec 02, 2007
  • lindigaf Dec 02, 2007
    your sharing a dial up line and a fax line? is that how im reading it? am i correct in saying that this is all it is?
SOURCE:
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
I can not send a fax with samsung scx-4521f
do a simple test. press the onhook button to you hear dail tone. try key in your mobile number and see if you got the call.
if all the above is yes there is no issue with the modem.
if you did not hear any dail tone. check your phone line is it working fine.
make sure that your phone line is not hunting line. fax machine does not work with hunting line. only direct line.
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
No dail tone on my fax sending screen. But there is dialtone in my telephone
Make sure the connnection is securely inserted on both end. If it is try new phone line from the modem to the jack on the wall.
May 24, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
Do I need a 56K PCI Data Fax Modem for my new computer? If yes, why? If not, why? Thxs.
You only need a modem if you are going to be on a on a dail up internet connection or want to use your computer for faxing.
If you are using a broadband internet connection like cable or DSL, then the modem is not needed.
Hope this helps
May 02, 2009 | Intel PC TEL 56K (pctel56k) Modem
OT OFF SENT REPORT & ON DIAL TONE
Try sending a test sheet using "hook" to a known good fax if it goes the fax is fine (it wont leave the doc feed till its coming out on the rx. fax.) If this works then maybe the speaker is bad or disconnected. As for the report you need to chance the transmission report to off or error.
-Carl, please let me know if this helps.
Mar 21, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
Modem dialtone problems
Is the phone line going to the modem live?
Jun 25, 2008 | Intel Motherboard
Fax busy, no response yet fax is sent ok
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Mar 18, 2008 | Brother IntelliFax-2820 Laser Fax
Could not receive and send Fax
Sending faxes and revieng faxeng through a pbx you need te configure the pbx and youre fax too.( Dail a 0 before youre messages! ) You have to connect always on the pstn line on the 210sf even if you use a pbx.
The Ricoh spc210sf isn't supporting an pbx on isdn line!! Watch out for this because the isdn line is working on 24Volts!! Then you can blow youre fax modem of the spc210sf .
You can contact me true email= [email protected]
Let me know is you encounter new problems?
Greetz
Richard Trip
Jan 16, 2008 | Ricoh Aficio SPC210SF All-In-One Laser...
Open Questions:
Computers & Internet Logo
245 people viewed this question
Ekse
Alun Cox
