The disk will drop but will only move a few inches before stoping. All of the belts are intact. The arm which holds the printer ink stops in the middle of the arm as well
Please fix the physical components of your printer particularly the belt and its rotator that causes the problem. I strongly suggest that you have to fix it or replace the components of the printer that is causing the problem. Also find a technician or shop that handles the repair of printer and let them repair your printer. Thanks
i have a hp deskjet 6110, indicates scanner filure and says to power off and restart but it does not...
(More)
i have a hp deskjet 6110, indicates scanner filure and says to power off and restart but it does not seem to work thereafter, help
gujhjhjkhh hfygjhkjkgjhk hgghjhfg gygyguhk that is what started happening to my prints on the disc...
(More)
gujhjhjkhh hfygjhkjkgjhk hgghjhfg gygyguhk that is what started happening to my prints on the disc then suddenly the housing that sits the ink came off the silver rail.
new pf3 will not print. keep getting error showing disk improperly loaded.  It will not...
(More)
new pf3 will not print. keep getting error showing disk improperly loaded. It will not even print a test disk.
