Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Le code come on
The machine don't spin
everything elses works
  • 40 Answers
When you press start on the machine, or initiate a wash cycle, do you hear any noise such as a motor?
Posted on Nov 29, 2007
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Machine won't spin...everything else working
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 21, 2010 | LG WM-0532HW Front Load Washer
I keep gettine the letters LE come up and my machine wont work whats does LE mean
if this is a LG washing machine code LE is motor fault call engineer
Feb 11, 2010 | Washing Machines
I'm getting a code LE on my washer. I saw one
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 06, 2009 | LG WM-2077C Front Load Washer
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
LG LE Error code
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
for more info check out this link:-
http://appliancejunk.com/forums/index.php?topic=1735.0
Dec 14, 2008 | Washing Machines
Le error code
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Try the above..........
Jan 03, 2008 | LG WM-3677HW Front Load Washer / Dryer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
49 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Marvin
Marvin
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
