Question about Symbol Spark LS 1004
Symbol Spark LS 1004 Problem
We have a Symbol Spark LS 1004 Barcode scanner in our library. Recently, we changed your old computer for a new one. But since that day, the barcode scanner doesn't work. When I scan the barcode, it does a beep like usual.. but the data doesn't appear in our software we use to borrow the documents.
The weirdest is that we put the scanner in the old computer again, to see what is wrong... and the scanner doesn't work at all in the old computer too. It reads the barcode, but the data still doesn't appear. We are totally clueless since the scanner was working fine on this old computer before we do the change.
We tried to set the parameters with the help of the product reference guide... but it's not helpful at all.
Do you have any idea what is going wrong with our Barcode scanner ?
Thanks!
Stéphanie V.
  • 5 more comments
  • Einnaf Nov 30, 2007
    I want to add something... This morning, I finally made the barcode scanner in our old computer. So, now that I see how I have to plug everything to make it work, I did the same thing on the new computer.
    Now the problem is when I plug the barcode scanner in the new computer, the data still doesn't appear AND the keyboard (which is USB compare to the old keyboard) doesn't work either.
    Is this mean that the barcode scanner is getting too "old" for the new computer ? (The new computer is a HP Compaq Intel Core2 CPU 6300)
    Thanks!
    Stef
  • Thomas Swan Sep 05, 2013
    Without being able to see the activity first hand, there could be a compatibility issue. What sort of system were you running before, and what are you running now?
  • Einnaf Sep 11, 2013
    Wow! I forgot about this.... So sorry for being so late to reply. The problem seemed to be a compatibility issue, so we decided to buy a new.
    Thank you all for your help!
  • Anonymous Mar 16, 2014
    Symbol MC3000 Barcode Scanner
  • Anonymous Mar 23, 2014
    need free referance guide for Symbol LS1902T-1000 USB Handheld Laser Barcode Scanner
  • Anonymous Mar 24, 2014
    I have plugged it in, and the laser is on but does not work. It beeps when I scan a barcode but the computerdoes not recognize it. even in a text document nothing seems to get inputted
    Scholar:
  • 58 Answers
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3380601bpdf&sliceId=&dialogID=33708056&stateId=0%200%205522749
If you don't know ask me. we don't want to lose al the settings.
good luck
Posted on Dec 07, 2007
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
I need to know the firing order for a 1992 oldsmobile cutlas supreme. I need to know what spark plug wire goes in what order on the cyclinders
1992 Oldsmobile Cutlass Supreme FWD 3.1 liter DOHC V-6 VIN "T"
1992 Oldsmobile Cutlass Supreme FWD 3.4 liter DOHC V-6 VIN "X"
Hope help with this (remember rated this).
May 31, 2010 | Symbol Spark LS 1004
How do i configure the LS1900 scanner for my library barcodes
You would need to enable the scanner for this barcode. It should be done by scanning the programming barcode "Enable Bookland EAN" from the LS1900 Manual at page 92 , located here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf&sliceId=&dialogID=189588721&stateId=1%200%20189576994
Feb 02, 2010 | Cobra Symbol LS 1900 (SYMLS1902T3000S)
Getting a symbol spark ls1006 to work with an hp pavilion dv6140ca
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Sep 07, 2008 | Symbol Spark LS 1004
LS 1004 Barcode Scanner
Mar 14, 2008 | Symbol Spark LS 1004
LS 1004 Symbol Barcode Scanner
The host type are the Interafces which are supported by the scanner directly (no adapter needed). And the Synapse adapter can even an old scanner connect to new interfaces like USB.
As you state you have the adapter for keyboard wedge. You would just need to download the Reference Guide for the "Synapse Smart Cable" at support.symbol.com a configure it acccording to your connection parameters.
Mar 13, 2008 | Symbol Spark LS 1004
Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Jan 22, 2008 | Symbol LS 4278 Barcode Scanner
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
What do you mean? you can only scan not more than 3 times? If that so,you need to change the setting of your scanner there was a limit numbers to scan. You can check by using the manual of that scanner.
Hope you like my solution please rate me SOLVE.
Best regards,
Philip
Oct 18, 2007 | Symbol Spark LS 1004
Symbol Spark LS 1004 Logo
831 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
