Question about Protron PLTV-4250 42 in. LCD Television
Pltv-4250 pip & pbp issue
How do i get it to work properly? Is it that it has a defect? I can't get either the pip or the pbp to work. The instruction book is not helpful at all...no trouble shooting for that sort of thing. when trying to use pbp picture side by side only one works. When trying to use pip only one works (either the little picture or the big picture. I see the words "pip no signal" . . . what does that mean? I am pressing the pip button on the remote... is it that I need to purchase a 2nd devise in order to make it work? Please help, thanks.
  • edmanracer Feb 07, 2008
    i have a 37 " Protron with the same issue i only get one picture to show i have video 1 with wii video 2 satellite video 3 2nd satellite component 1 dvd and when i hit source it only gives me sub: vga or coomponent 2 or Dvi option from pip source button ....
    President:
  • 2,961 Answers
Yes, PIP allows you to view 2 channels at one, one being the analogue picture another being a cable/freeview or sattelite picture, if you only use one of these to view programmes, you will se a blank screen.
Posted on Nov 29, 2007
How do i fix protron
Here is a great link for the manual:
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=21#manual
Try page 21 through 25. There is no "factory restore" function, but you can adjust the hue and colors.
Hope this helps. PROTRON PLTV 4250 User Manual Using The Remote Control
Mar 22, 2015 | Protron PLTV-4250 42 in. LCD Television
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Protron pltv 4250 keeps shuting off
Main digital board should be checked. In most case, might need replacement. Contact any service technician.
Jun 27, 2013 | Protron PLTV-4250 42 in. LCD Television
I have a protron pltv 4250. I don't have a remote control and the tv is stuck on pip. so i have 2 screens one shows the tv program and the other screens stays blue. What can I do to fix this...
Few universal remotes will provide functionality to any but the most basic of functions.
PIP only functions properly when being used with HDMI.
I feel you will need to buy a dedicated remote. I found some on Amazon for a reasonable price.
Feb 04, 2018 | Protron PLTV-32 Television
No video on my Protron PLTV 4250
check the video with a flashlight against the screen, if present the backlight inverter has failed.
Dec 07, 2008 | Protron PLTV-4250 42 in. LCD Television
No sound on PLTV 4250
Easy! If you have a VCR,put a VHS tape in the VCR,run the video cable behind the TV and the audio cable from the VCR to a hi fi receiver/speaker(cd input or tape input.)
If you have sound coming out from the HI FI,go ahead and plug the audio connection along with the video connection behind the tv.If there is no sound, it could be:
A. your TV speaker is completed its mission-;o)Blown speaker.
B. you are on TV MUTE!
C. your audio cable is defective(small chance,cause you have left and right!)
D. your connection was incorrect.
solutiondoct
Oct 13, 2008 | Protron PLTV-4250 42 in. LCD Television
THE POWER JUST SHUT OFF AND WILL NOT COME ON NO MORE
power supply for this model are defective and you cant find a replacement anywhere you might be able to get someone to repair the old one or build a new one i have 2 of these tvs in storage both w/ same issue
Jun 05, 2008 | Protron PLTV-4250 42 in. LCD Television
Removing the stand/base off of the PLTV-4250
I did the same exact thing. I unscrewed the main screws holding on the base, the rods run up through the TV, and I still couldn't get it to come out. So, I went and hired a repair guy to come and tell me what I was doing wrong and he said it should come right out. All he did was give it a good hard yank, and out it came. I was afraid I would tear up something, but it worked. Good luck. P.S. Those idiots at Customer Service don't care at all.
Dec 01, 2007 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV-4250 42 in. LCD Television Logo
82 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
