Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Mitsubishi WD-52725 Lamp was replced 9-13-07 and on 11-2607 tv goes dark and lamp light glowing solid red. The sequence is:1. TV gets power and timer/power light blinks fast (about 1 minute).2. timer/power light stays steady green.3. seconds later lamp light stays steady red. (never a sign of light)According to the manual this indicates "lamp has failed" but the lamp is new and shows no signs of poping. Is there a known problem with this set? Resets don't help. Fans are good and running. Any ideas would be appreciated. SE
  • 5 more comments
  • babyboyyouth Dec 10, 2007
    I put in a bulb after the red light came on and nothing happened , tv turned on and i heard a noise in the the tv like something was spinning and it stopped , tv then shuts off after like 2 mins and the red light came on indicating bad lamp , i dont understand what is wrong , do i need to just trash the tv ? what else could be wrong with it ?
  • Anonymous May 10, 2008
    I'm having the same problem. How did you fixed your TV?
    we have the same problem with our tv. and we were woundering what kind of lamp it takes? because we dont have a manual.
  • oh58 May 13, 2008
    Same problem . Mitsubishi sent an entire chassis (lt side of set and all boards, I installed and same problem. Mitsubishi said this should take care of problem but they will no no more.
  • Anonymous May 24, 2008
    I have the exact same problem. With the exact same TV WD-52725.
  • 15Rod May 24, 2008
    I have the exact same problem with the exact same tv WD-52725
  • keithanne Jul 01, 2008
    Replaced lamp in March 2007, now red light comes on and indicates bad lamp.A tech came out and said my DB board is bad.No more Mitsubishi.
  • 39 Answers
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Posted on Nov 30, 2007
Tv won't power on anymore. i get a solid red light. why?
Solid red light means the lamp has failed. Try replacing the lamp first. Mitsubishi DLP TV Bulbs
These folks have the proper lamp you need and have a 6 month warranty
Sep 16, 2015 | Mitsubishi WD-60735 60" DLP HDTV
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Red light came on indicating the lamp.And it keeps cutting itself off
The projection lamp has not been replaced in this tv like 1 1/2 or 2 years?The tv projection lamp life are over.Require a new projection lamp.
Oct 06, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
I have a mitsubishi WD-52525 DLP Tv; I replaced the lamp, powered on the system, I hear the fan go on, the green wait light goes solid after a few seconds and a few minutes later the lamp light goes solid...
Chances are the lamp is not bad. Is the lamp door reseated properly? The is an interlock on that door that must be activated in order for the set to turn on. If the unit was woking before the lamp went out this may be the problem
Nov 26, 2008 | Televison & Video
Random, intermittant blue lines
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
353 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
