Question about GE Profile Spectra JGBP90 Gas Kitchen Range
F2 error I don't have the instruction manual for my spectra oven. WHen I use the broiler I get an F2 error message after a few minutes of broiling. I am not sure if the oven door is to be slightly ajar or closed while broiling either. Please help! Mary
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
An f2 code means the oven overheated.it could be a bad relay on the control board. also if you ran a self clean cycle and left the racks in the oven,i've heard it could cause problems with the oven sensor.
and no you shouldn't have to leave the oven door open when you cook.hope it helps
Posted on Nov 30, 2007
Unit shuts off when using broiler
can't broil with door open with these models. If closed, most likely an air flow issue with the cooling fan above in the control panel.
Nov 15, 2013 | Thermador C272 Electric Double Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Error code f2 broiler comes on by itself and won't shut off
F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
I can not find my manual for the range. I have a
Hi casharri,
Go Follow the link to get the manual =
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=ITEMID&itemid=49-85020
error F2 = Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Regards
R.K.
Oct 15, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Oven and Broiled will not light - GE JGBP30 oven
I think it was the 'Guest' who commented on this and we just exchanged information again.
You can read it here:
GE Oven-Broiler problems
Feb 08, 2008 | GE Spectra JGBP30 Gas Kitchen Range
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
222 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
