Question about Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Mp4 i am unable to turn on the player unless it is plugged into an electric supply. I have tried charging it but it is just not keeping any charge. My email address is [email protected]
The same thing happens to mine! it sucks
until, i phoned up samsung..they said put it in the freezer. i know it sounds silly but by putting it in the freezer the cold air allows the electrical particles to become free due to the negative charge present. (i researched a lot) do it for 24 hours-25hours no more than that..press the reset button afterwards! mine totally worked normally again.
Posted on Jan 10, 2008
  • MCRTBP Jan 10, 2008
    IM KIDDING..BUT TRY PRESSING THE RESET BUTTON
SOURCE:
Mp4 player 4gb
According to an earlier fixya post by spoil5, it's a common problem with Transcend mp3 players usually because of a defective battery and/or the operating firmware.
Transcend MP 860 Review
His tips:
  • Keep the battery charged, don't let it go flat
  • Try the trick with the volume control
  • Replace the battery
Here's his temporary fix to make charging work:
  • Turn on player.
  • In main menu press and hold the rocker button in up position.
  • You should see volume adjustment indicator.
  • While volume indicator is increasing, plug USB cable connected to turned on power supply.
Important: the volume must keep changing at the moment of plugging the cable (cannot be stopped at max position). If necessary set volume to 0 first and then start from 2.
Check out this solution to the Transcend sonic 610 MP3 Player problem...
Feb 01, 2014 | Transcend Audio Players & Recorders
My MP4 player won't work unless it's on charge
system ic failure....battary charging circuit is not initiated due to system ic failure. i think some supporting component like capacitor is defective. better chek with good skilled tech....
Feb 04, 2018 | Apple iPod nano 3rd Generation
The mp4 player will be fully charged and when i take it off the charger and i want to listen to it. It will pause and freeze then will turn off right away. I will try to turn it back on and it wont turn...
i think in 3 possible solutions: 1- try to charge it with another charger 2- connect your mp4 to a computer and run a virus scan, after this try it. if don't, format your mp4 and try to charge it again. 3- the charge system of your mp4 is damaged, so take it to the technical support for to repair it.
Aug 05, 2011 | Mach Speed Trio V430 MP3 Player
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
My konaki mp4 player wont charge
maybe your mp4 player is switching off... try to turn on...
Jun 01, 2009 | Konaki MP4-NS MP3 Player
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Mp4 player iboost
HOW CAN I UPDATE THE FIRMWARE ON MY IBOOST DEVICE
Jun 16, 2008 | Audio Players & Recorders
Craig mp4 players
try hookin up to the computer USB Port, and see if there is a charging Icon On The MP4 Player. leave it hooked up to the computer for 2-3 hours, then try it.
if non of this works, the internal batterys dead.
you can get replacements for these if you need 1.
theres a lot of chinese companys, that supply replacement batterys as spares.
Mike @ compurepair.
Feb 22, 2008 | Audio Players & Recorders
Craig mp4 player
Keep your mp4 player turned OFF while charging and keep it in for an hour. Let it charge up. If that doesn't work something else will - Follow these directions carefully!
1. GENTLY hold your Craig MP4 player in hand. 2. Walk over to window and hold it near sunlight for 2 minutes. 3. Shake it gently 3 times. 4. GENTLY place it down and wait 2 minutes. 5. Grab mp4 player and smash it into trash can.
Voila! Problem solved!
Jan 08, 2008 | iLO (2 GB) MP3 Player
No brand-mp3 mp4 player
well this has never happened to me but mine did freeze o all you have t do (this might work) when it is on try holding down the power button for about 20-30 sec and it restarts it. thTS WHAT HAPPENED FOR MINE WHEN IT FROZE FOR THIS PROBLEM IM NOT SURE IF IT WILL WORK but give it a try
May 23, 2007 | SanDisk Sansa e250 MP3 Player
Open Questions:
Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player Logo
35 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
