Por que el monitor dell e151fpp se apaga momentã¡neamente estando prendido
SOURCE: Dell E151FPp 15" TFT LCD
It does not have DVI port, only VGA. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://support.dell.com/support/edocs/monitors/e151fpp/En/attach/attach.htm
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: Monitor problem
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
SOURCE: BUENOS DIAS EN QUE ME PODRIA AYUDAR YA QUE MI
Parece ser que tienes un problema de recalentamiento del CPU. Es muy comun que con el tiempo, se acumule polvo dentro de las laptops. Las laptops se apagan solas pues responden a un sistema de proteccion que tienen para evitar daños mayores al sistema. Como medida inicial, use una aspiradora, y busque donde estan los ventiladores, para remover el polvo acumulado. Espero que esto le sea util
SOURCE: recuperacion de sistema
COMIENCE, FUNCIONE, MSCONFIG, LENGüETA de Boot.ini Las 2 trayectorias del cargador se deben enumerar allí, y la que doesn' el trabajo de t se enumera como DEFECTO. Destaque la trayectoria funcional del cargador, chasque el SISTEMA COMO botón de DEFECTO, entonces AUTORIZACIóN
in English:
START, RUN, MSCONFIG, Boot.ini TAB The 2 boot paths should be listed there, and the one that doesn't work is listed as DEFAULT. Highlight the functional boot path, Click the SET AS DEFAULT Button, then OK
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
