Question about GE DPGT750GC Gas Dryer
GE DPGT750GC Gas Dryer Problem
I recently moved, and I connected my washer and dryer in my new home. Washer works great. Dryer, connections are good, I have power, but the screen says" Notice there is a problem with this unit. Please call..." Is there a reset button on this model? why does this message usually come on? and what can i do or check on to make this message dissappear? Thanks!
  • Anonymous Jan 13, 2008
    Same symptom as originator's unit.
    Unfortunately, cannot start the troubleshooter as the response suggests. All keys are ignored (actually, they result in one beep and the same error screen.
    Any idea how to either reset this, or get it to spit out a little detail as to the specific problem it sees?
    Thanks!
I made the 'Guest' post last night, and have since found more info.
You can enter service mode by:
1. Power on (press 'POWER')
2. Press (and release) 'HOME' (will beep twice I think but doesn't matter)
3. Press (and release) 'HELP' (again with the beeps)
4. Press (and hold) 'MY CYCLES' and 'BACK' together (hold for ~3 seconds)
It will then give you more detailed info as to the specific problem, plus suggestions for what to check. When you exit service mode (via on-screen 'EXIT' touchbutton), it will tell you that you have to unplug the dryer to reset it. After replugging, it will run a setup/diagnostic which tests the door switch, panel buttons, touchscreen, beeper, motors, heating, etc.
Posted on Jan 13, 2008
  • 259 Answers
Using the
Troubleshooter
To locate Troubleshooting Tips for common dryer
problems:
Press the HELP button.
2 On the Touch Screen, select TROUBLE
SHOOTER
3 On the Touch Screen, select the problem
description from the list. You can use the arrows
at the right of the screen to scroll up and down
through the list of additional problems.
4 On the Touch Screen, select a possible cause
for the problem and follow the on-screen
instructions to find a solution.
Pressing the HELP button then selecting HOME
SCREEN HELP
allows you to find additional
information on features found on the Home
Screen. Touch any pad on the Touch Screen for
an explanation of that feature. To exit the feature,
press the BACK button.
DID YOU ATTACH THE SERIAL CABLE?
Attach the serial cable for washer and dryer
connection to the serial port on the back of
the dryer.
Attach the other end of the cable to the
washer before pushing the washer into its
final position.
Problem Possible Cause What To Do
Dryer won’t operate Control panel is asleep • This is normal. Press POWER, the
touch screen or any button to activate
the control panel.
Dryer is unplugged • Make sure cord is plugged securely into
a working outlet.
Controls are not set properly • Make sure the cycle was set correctly,
close the lid and press START.
Fuse is blown/circuit breaker • Check house circuit breakers/fuses.
is tripped Replace fuses or reset breaker.
NOTE: Electric dryers use two fuses
or breakers.
Electronics need to be reset • Unplug dryer, wait 2 minutes, plug
back in and press POWER.
START was not pressed after • Press START.
a cycle was set
Door was opened during • Close the door and reset cycle, to the
the dry cycle beginning if necessary. Press START.
Dryer is too cold • If the dryer has been exposed to
temperatures below freezing for an
extended period of time, allow it to
warm up before pressing POWER.
Otherwise, the display will not come on.
Hope some of this helps. here is a link to the manual:
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=DPGT750GCPL
Posted on Nov 29, 2007
Need hook up diargam for 240 volt 30 amp washer dryer residential xyo-gnd recepticals.now for free .like your web site said. or i will presume this is just a scam trying to lure people in for some...
Hi Watsonelecco!
No scams here... most of us on FixYa are like me.... we enjoy helping people out with their everyday problems. I work nights and do this as a hobby... I used to teach advanced electronics and Radar for the US Navy.
It is difficult for me to give you a diagram for "xyo-gnd" since the term is not familiar to me, even though I worked as an industrial field service engineer. My guess is that you need to connect your washer/dryer to your electrical outlet.
First thing.... I need to know where you are located, and what type of power service you have coming into your home. Most US homes are wired for 115 Volts and require a separate input for 230 volt appliances. Most European, Australian, and Asian homes are wired for 230 volts and connecting your washer/dryer will be simpler, but still require some work.
The first thing we will need to know is how the power comes into your home and how it is distributed. Look at your circuit breaker panel. You will have a mains coming in that feeds a 2 pole "main" breaker- it will be rated at between 100 and 300 AMPS in most homes.
Next... the other breakers in the panel.... how many are "2 pole" breakers (what looks like 2 switches connected together) and how many are single pole? Only a 2 pole breaker can supply power for your washer/dryer.
Now, you need to determine which of the two pole breakers are rated high enough for 30 amp service. If none say 30 amps or higher, you will need to install a new breaker and run a 10/3 AWG type UF cable to where you are installing the washer/dryer. Find a recepticle that matches your washer/dryer plugs, and install it with the black wire to the brass lug, the white wire to the silver one, and the green wire to the green lug.
Once you have the wiring done, you will be good to go!
If you already have a dual breaker rated at 30 amps supplying an outlet where you are installing the washer/dryer, match up the plugs/outlets the same way... black wire to brass, white to silver, green to ground. You may have to purchase either the correct outlet, or (more likely) the correct plug, since most units do not ship with power cords.
Apr 07, 2011 | Microwave Ovens
Kenmore Washer/Dryer Combo Unit Cord Issue
the extra prong is just anothere earth over here we hacve three prongs and 2 prongs its just a better earth thats all and it wontstart a fire ii always change mine i did it to my toaster,microwave,iron,and pc all over 1 yr ago nothing ever happened
Sep 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
How do I prep my Kenmore Elite He5t washer for move to new house
Washers n dryers usually require some balancing after a move to the new area, and when you lift the washer on a dolly, you lift it from the rear. Assuming you've already tipped the washer slighlty to one side, checked the bottom for which side has the most metal underneath. This is best done with 2 people. Do the same with the dryer. The braces are used to help balance or to keep from tipping when the machine was packed inside a large box.
May 23, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Hoove HM6316M Dryer not drying
Where was the water leaking from ?
Has it leaked onto the dryer electrical connections ?
You need to check if there is a circuit board behind the fascia panel.
please let me know these answers
good luck
Jan 25, 2009 | Hoover HW6 160M Front Load Washer / Dryer
Keep the dryer from moving around on the washer
It may be bolts loose in the back where Over Under washer/dryers are connected.
Good Luck!
Jan 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Stackable washer dryer
hi thanks for the question the washer has a separate cord for 110 volts see if its plugged in thanks the appliance doc
Sep 27, 2008 | Kenmore 62602 Electric Dryer
Dryer
i used to do warranty work for LG needless to say, after finding out customers were waiting up to 2 1/2 months just to get parts i stopped doing any work for them. if it were me, i would take both the washer and dryer back and buy a bosch instead. much more reliable and there customer service is great
Nov 28, 2007 | Dryers
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Open Questions:
Dryer is acting up. so, it hasnt been used in about 2 months.  it sat out in a cold garage.  but was back up to 'room temp' when we hooked it up.  the gas line is secure.  the venting is proper.  the dryer's level.   after turning it on, not much has happened.  a faint 'beeping' signal comes out of it every few seconds or so, and signal lasts about 2 secs.  the dryer will tumble and kinda gets a weak luke-warm.  i heard this clicking (blower motor i think) as if it were a rotating clicking noise.  then i heard what sounded like a piece of plastic drop.  then poof! the blower kicked on and the dryer started crankin'! working great.  thought maybe something needed to settle.   note* i did have this dryer on its side while moving it in the back of my pick-up truck.  (which was covered from the elements w/ a cap & laid on soft blankets).* after several uses some serious noises started coming out of it.  a severe clicking rotating plastic thumping, sounded like hard plastics banging, clicking rotating, hard to explain.. i reset the dryer.  now it starts up, and just rotates, blower never kicks on.  doesnt really get hot, back to a weak luke-warm.  (i threw a wet towel in there..nothing, no heat/blower)  nothing going through the vent either.  so..i was thinking about pulling the back off, but figured i'd ask you guys first. also, do you think it's worth it to call in a Sears professional?  costs involved?   yeah man, any help would be appreciated, the thing's out of warranty, and well..i need a working dryer, full household.  laundry piles up!   - thx, Angelo
Feb 28, 2017 | GE DPGT750GC Gas Dryer
GE DPGT750GC Gas Dryer Logo
443 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
