Question about Magellan RoadMate 700 GPS Receiver
Inputing addresses I can't put in a highway address. such as: 3707 w. highway 80
    Scholar:
  • 59 Answers
Try to find a Point of Interest that's on that highway (like a Mall, Bank, Drugstore, etc.). Then, see how the address for that POI appears in their database. That will give you an idea of what shortcut they're using for that particular highway.
Posted on Jan 06, 2008
SOURCE:
I want this billed to my amazon account and delivered to another address
When you put an item in your basket and then go to check out it will ask you what credit card you want to use. Then it will ask you what shipping address you want to use. You will have to input the new address I hope this helped
Mar 09, 2015 | Amazon Tablets & eReaders
Is there a way I can block someone from emailing me if they keep bothering me?
here's a video in which you can follow: http://www.ehow.com/video_4991395_block-yahoo-email.html
or follow this steps:
1. Login to your Yahoo! Mail.
2. Go to the upper-right corner of the page and select Options. Click on Mail Options from the resulting menu.
3. In the left pane, select Spam.
4. Go to the Blocked Email Addresses section and input the desired address you wish to block into the Add a blocked address textbox. Click the Add button.
The address will be blocked from putting mail in your inbox. If you change your mind, you can easily remove the block by going back to the Blocked Email Addresses, selecting the desired address from the list of addresses and clicking the Removebutton.
Aug 23, 2011 | Yahoo Mail
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
HOW DO I REPROGRAM ADDRESS BOOK
First I will refer to instructions for the KM-5035 which is the same copier as the CS-5035. The instructions, utilities and manuals are interchangeable.
It depends on what information you are looking to program.
If you want to input Scan to Email - email addresses or scan to PC - addresses directly into the network card so they show up on the copier display you can do it from your computer web browser.
If you put the scanner card IP address into the web browser like yo would enter a website address it will open up the scanner network card and if yo look down the left side of the webpage there are links to take you to the correct page to input the information you need to.
You can also use Kyocera's Scanner Address Editor to load this information. This is a utility that can be downloaded to your computer and then run to input the information. You can download the utility from this link http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11783&rid=17521.
For Fax numbers you can not load them from the web browser but you can load them from Kyocera's Address Editor for Fax. You can download the utility from this link http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11783&rid=17669.
You can also add fax numbers and email addresses from the copier's operation panel
To download manuals go to Kyocera's website at this link http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=11783&pcat=10564&rcid=10009&rscid=10028.
The Scan System Operations Guide covers the use of the utilities.
Let me know if you need more information. Also you can find useful setup information at www.gfbm.net.
I hope this is helpful,
Shawn
Jan 29, 2011 | Kyocera Copystar CS-5035 Copier
No matter what address i input, it can find the location but when it start navigate, the map turns out a location in Kansas..i dnt know why is that..i input washington state address
You need to change the State. When you go to put in the address does it show the state as Kansas. If so press change state and change it to Washington.
Jul 19, 2010 | Garmin nuvi 260W GPS Receiver
Set up email/scan
moz-screenshot.pnghere's how to add contact to the address book:
  1. press FUNCTION key
  2. select FAX/EMAIL SETTINGS icon
  3. select ADDRESS BOOK
  4. select ADD EMAIL ADDRESS
  5. input your email address
  6. input your name
  7. select ok
  8. input a key name
  9. you can choose if you want to add it to favorites or not
  10. press stop key to return to idle state
that's it :)
Jun 12, 2009 | Panasonic DP-8045 Grayscale Copier
Can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
Nav-cam 2007
The "Origional" software will not allow you to input a street address. The newer N30 software will input street addresses, as well many more POI's, as well as via directions. I have the original software, plus the newer N30 software. Let me know if I can help! Joe
Oct 20, 2008 | Evesham Nav-Cam 7700 GPS Receiver
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Set up the DWL-G710
Make sure you are using the right range of IP addresses, for instance, if your device has a default address of 192.168.0.1, then your computer must have a manually input address of something like 192.168.0.2, otherwise the devices will not communicate. You can change the address on your computer be going into your network connections folder, right clicking on your LAN folder, selecting properties, then right click on TCP/IP protocal on the protocal list, and also select properties. Here, you must uncheck the "Automatically Obtain IP Address" option and input the address shown above. The next two boxes will be 255.255.255.0 and for Default Gateway enter your devices IP address. Don't worry about the DNS address for now. Press ok to save the settings. You may have to restart your computer when you are finished. I hope this information helps you. Good luck!
Nov 05, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
Magellan RoadMate 700 GPS Receiver Logo
158 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
