Question about Fisher FVH-T607 VHS VCR
Erratic video playback
VHS tape playback is OK for awhile then appears to drop sync for a frame or 2, then plays OK again. This happens over and over.
Heads have been cleaned with "wet system" cleaner tape.
This same tape plays OK on another VCR.
0 characters
1 Points
How do i playback s-vhs compact cassettes ?
S-VHS tapes will only playback on an S-VHS machine, it will play them automatically when inserted. A normal VHS machine cannot play back an S-VHS tape.
Feb 27, 2015 | VCRs
I have the remote the date etc. programmed OK but how do I set up the actual recorder with undefined
Panasonic are very good at having free PDF copies of user manuals. However if you just want to playback old tapes then all you need do is connect the vcr to a TV and press play. You might need to adjust the tracking using the controls on the remote. But the picture should play. If you see snow on the screen, but can hear sound, then the tape heads will need to be cleaned. You can get a VCR cleaning tape for that.
Oct 29, 2014 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
My family videos are stored on the mini VHS tapes. I recently bought a VCR to dvd recorder to transfer them into dvds but now I discover my VHS playpak (that you need to play the mini tapes) is broken....
Maplin Electronics have a motorised VHS-C Cassette adaptor that will enable you to view any camcorder tape on a standard VHS. If that is any help priced around £15.00.
Mar 14, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VHS Video Tape - Picture Roll.
Picture roll is caused by the frame rate being out of sync with the play back device. If the tape was recorded at say 25 f/m and is being played back at 26f/m. If you can, adjust the frame rate until the picture stands still.
Mar 30, 2010 | Philips VRX242AT VCR
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo VCRs
Audio clipping during VHS (S-VHS) playback.
Have you tried the Panasonic site, they have PDF (free) of user manuals?
Sep 11, 2009 | Panasonic AG-DS555 S-VHS VCR
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr. play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
VHS system malfunction
VCR's automatically detect what speed the present tape was recorded at. It only gives you a choice of speeds when doing the recording. If you are saying that it won't playback a tape recorded in one of the slow speeds, it is most likely because VCR's with more than two heads use different combinations of them in different speeds and the ones used for slow speeds are maybe needing cleaning. If this is the case, the vcr will seem to be playing OK, but the video playback will be bad.
Dec 25, 2007 | Goldstar GVR-DD1 VHS VCR
Philips vr630 vhs
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
Jul 14, 2006 | Philips VR630 VHS VCR
VCRs Logo
Top Fisher VCRs Experts
Jose Ma DM.
Jose Ma DM.
Claude Kayser
Claude Kayser
Are you a Fisher VCR Expert? Answer questions, earn points and help others
