Question about Alpine CDA-9805 CD Player
Alpine CDA-9805 head unit - frequency hops
When head unit is turned on...everything works fine for a bit, then the frequency hops around. Example (Tuned to 106.5 FM, then all of sudden frequency hops around, but still displays 106.5) After a short bit the original signal comes back on. I've check the antenna and its good.
Sure could use some advise.
B. Nicol
email: [email protected]
    Sergeant:
    Champion:
  • 231 Answers
Make sure no switches are jammed on radio or radio face.Liquid spillage and or intermittent switches on tunning section can also cause this.
Posted on Nov 29, 2007
SOURCE:
What's your problemI bought a used car that has an alpine cda 9805 radio. It has an auxillary cable that appears can hook up to my I pod nano. I can't find the function/ mode on the radio to g
The source/power button in the top left corner changes the mode. Press the button until the aux appears. The auxillary device must be plugged in to register on the stereo.
Aug 19, 2012 | Alpine CDA-9805 CD Player
Set clock on a alpine cda-9805. I can change hr not min
Heree is how to set the time on the radio.
1 In the Clock priority mode, press and hold the DISP/
TITLE button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
time indication is blinking.
3 When the hour has been adjusted, press the Rotary
encoder.
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder
If you need the manual is on the link below page 6 tells you how.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9805.PDF
Good Luck
Nov 06, 2010 | Alpine CDA-9805 CD Player
Intermittent power to head unit
no inline fuse? I usually just slip the wire inside the battery connector, remove connector lay wire across battery with stripped end running up the side of the battery terminal place connector down on terminal and wire, tighten connector back up.
Feb 21, 2010 | Alpine CDA-9805 CD Player
My display stays on for about 3 seconds then it turns off until
If this model has a detachable faceplate,
Remove the faceplate and clean down the contacts with metho and a cotton bud.
Over time usually corrosion and dirt etc builds up on these terminals making them loose cotact when you touch the faceplate.
This is the most commonly known problem alpine units.
Other common problems is the power supply failing /amplifier.
Hope this helps you out
Cheers
Steve
Apr 02, 2009 | Alpine CDA-9805 CD Player
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Alpine CDA-9805 CD Player Logo
178 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
