Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Pink and Green on Non HD Stations
By TMolan on Nov 29, 2007
When viewing our Sony Bravia TV on Non High Definition Channels everything is Pink and Green. I tried adjusting the Red-Green adjustment and it made no difference. On High Def Channels all colors are perfect.
Same Problem
Apr 11, 2009
-   I have the same problem, on both a Sony 57 rear projection LCD hd tv and our new Sony Bravia 52 LCD tv. Is this a Sony problem or a hdtv problem?-   idaley
Feb 16, 2009
-   46L550 -   Guest
Jan 24, 2009
-   I have the same problem with a Sonny 46 inch bavia LCD. When I go to any of the non HD channels when using the HDMI connection the color blue is not present giving a dull green color. When I use the component mode it is fine.
Does anyone know what the problem is ?
MIke B
-   mbrad46
Dec 07, 2008
-   I have the same problem when changing the channel from HD to Non HD. If I turn the TV off and back on everything is OK. The TV is a Sony rear projection LCD 60" purchased in Oct or Nov of 2006.-   elrondw
Dec 06, 2008
-   I have same issue - usually when swicthing from HD to non-HD. I have to turn TV off and then on again. -   Guest
Solution #1
posted on Feb 19, 2009
Somewhat Helpful)
mbrad46
Rank: Apprentice
Rating: 75%, 3 votes
This problem can be fixed with the cable box settings !
Was this helpful?
Yes
No
Solution #2
posted on Feb 16, 2009
Somewhat Helpful)
rosette175
Rank: Apprentice
Rating: 75%, 1 votes
samsung 46L55 hdtv 1080p red and green tinge on darker images
Was this helpful?
Yes
No
Solution #3
posted on Nov 30, 2007
Somewhat Helpful)
electroguy
Rank: Guru
Rating: 87%, 111 votes
what is model of unit?
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
While watching TV, every once in a whule the sound changes and it sounds like an echo/blown out... (More)
Answer
What is a good still camera to buy?
Answer
i have an olevia 540 lcd,tv has sound but no picture
Answer
Standby indicator flashing red 8 times . Model LCD Sony Bravia KDL40 L4000. Thnks
Answer
3 year old Westinghouse TV has audio, but no picture. Is it repairable? Where? By whom? Model... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , FL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
