Question about NEC VT465 Multimedia Projector
Projector giving upside down picture
Had a look on menu for the mirror button carnt find it i have a oley ptv do288 can anyone help for the picture to be the right way
  • 752 Answers
For the VT465 it is in the menu under "setup" then "orientation".
Page e-24 of the manual.
http://www.douglas.bc.ca/__shared/assets/NECVT_660K_MANUAL32261.pdf
Posted on Nov 29, 2007
I bought Projector DGTEC PR80 and I can NOT find how to rotate the picture, as I hang it on the ceiling.
Have you found a MENU button? Usually the remote has more configuration features. There's usually a Picture section where you can turn the picture upside down or mirror it for rear projection.
Nov 18, 2015 | Office Equipment & Supplies
Xd500u prjector image upside down
Use your remote to access the image menu(menu button). scroll to the Mirror Invert selection. select invert.
Apr 05, 2012 | Mitsubishi XD500U-ST DLP Projector
Ceiling-mounted benq projector giving upside down immage? how can i reposition the immage? thanx
it should be an option in the on screen menu to flip picture
all projectors have this as option
it will be under "source" and it is "mirror" setting
good luck
Mar 21, 2011 | BenQ PB6100 Multimedia Projector
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
I have an NEC projector that the image has flipped so it is upside down. How do I fix it?
1. Click on the Menu button, either with the remote, or using the controls on the projector.
2. Use the Select control, scroll to the Setup tab at the bottom and click Enter.
3. Use the Select control, scroll to the Installation tab on top and click Enter.
4. Use the Select control. scroll down to Orientation and click Enter.
5. Use the Select control, choose the Front option that gives you the correct picture. (The Rear options are only used when projecting through a mirror)
6. Use the Select control to highlight OK, and click Enter.
Jan 13, 2011 | NEC MultiSync LT280 LCD Projector
My picture is backwards. If you hold a mirror up to it and look in the mirror to watch it, it appears correct.
go into your menu and change the picture settings. The projector is set up to shine through the back of a screen.It can also be set for upside down,to hang from a ceiling.
Dec 21, 2010 | Office Equipment & Supplies
Why is image upside down? the image appears inverted on the board
You need to set up the image using the menu. Press menu button on the remote then use the arrows to go down the list until you come to "mirror". Now press the enter button on the remote several times to cycle the orientation of the image (on some remotes you may have to use the right arrow button instead of the enter button). The projector will remember this setting next time it is switched on. These options are there for people who use ceiling mountings that hold the projector upside down.
Jul 10, 2009 | Epson EMP-S3L LCD Projector
Icon medialab projector -upside down picture
I can not find the manual for this projector, but on most projectors in the menu you select the position of the projector. You will need to select front/ceiling. If there is not a installation tab on your menu, look under setup. Hope this helps.
Mar 12, 2009 | Office Equipment & Supplies
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
NEC VT465 Multimedia Projector Logo
1,216 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
