Question about NEC MultiSync 1760NX 17" LCD Monitor
Resolution notifier v71lcd
Resolutin notifier message pops up every time i fire up my computer i find it very annoying. my pc : compaq presario SR1303WM my monitor Mitsubishi V71LCD I keep getting a resolution notifier when I start up my computer and when I change programmes. It is very annoying can anyone help
4 Suggested Answers
  • 1314 Answers
SOURCE: NEC 1940 CX Monitor
Here's the user's manual: Basically, according to the manual, you have to go into your menu and turn off the resolution notifier.
Posted on Jun 15, 2007
SOURCE: NEC 1770 monitor
click Menu, Menu/Tools, scroll down to Resolution Notifier and choose Off
Posted on May 23, 2008
  • 3153 Answers
SOURCE: message received is
This is similar to the "out of range" message that many flat monitors give when the resolution is maybe higher than the monitor would like.
It has given you the suggestion for a good reason. As with most monitors flat or crt it is possible to shorten the life of them if you abuse them in this way.
My suggestion is to lower your resolution to the one it offer you.
Posted on Aug 25, 2009
  • 120 Answers
SOURCE: The resolution notifier keeps popping up (NEC
It probably is warning you that your video graphics adapator is puting out a non-native resolution to the monitor.
LCD monitors are designed for a specific resolution. If you don't use that resolution, the LCD has to try to mimick the resolution you've asked for.
Check your display settings and also consider updating your graphic driver if a new version is available.
Posted on Oct 13, 2009
0 characters
1 Points
Will a hp vp17 monitor work on a compaq presario?
All monitors will work on any pc/mac computer.
The only concern might be how old is the monitor (low resolution) connected to a brand new computer (high resolution). But it usually auto adjust at windows boot up.
Check the VGA connector (blue) or DVI connector (white) for the monitor matching the pc tower
Feb 24, 2015 | HP vp17 Monitor
Can you please tell me the recommended resolution for Compaq MV7540 17 inch CRT monitor?
The recommended resolution depends upon your preference and the capabilities of you graphics card. I suggest you start with 1024x768.
At some resolution the image may be stretched and a circle may appear a slight oval shape. If this is annoying then adjust the resolution accordingly.
Oct 16, 2010 | Compaq Computer Monitors
Resolution problem cannnot get the correct resolutin for E152FD
Hi, if your monitor is 15 inches, then you probably should set your resolution to 1024x768.
If this answer helped you, please leave a positive feedback.
Jul 18, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
I have a NEC LCD 1760V and the resolution notifier keeps popping up. How do I eliminate this problem. It keeps telling me to exit.
insert the AGP card in the AGP slot in install the drivers the problem will be definatly solved the card should be of 8X grade
Mar 04, 2010 | NEC-Mitsubishi Nec Display Solutions...
Monitor menu keeps popping up for no apparent reason and pops out when it pleases. I've had it over a year and it just started doing this yesterday.Very annoying! IT JUST DID IT AGAIN!!! Tried system...
Are you running DVI or AGV? Try swapping from one to the other if it possible.
Is it a possible resolution notifier? My old LCD did that just to tell me what is what. Annoying as hell but I couldn't turn it off.
I can suggest turning the resolution down a level. See what happens there. Or possibly the refresh rate.
Jul 09, 2009 | Envision H191W Monitor
Resolution Notifier pops up every 30-45 seconds
Do you have an NEC display?
If so, it is part of the display's programs. Use the buttons on your monitor to select the "menu" then scroll to find "Resolution Message/Notification/Error" and disable or off.
This should do it.
Jul 19, 2008 | NEC-Mitsubishi AccuSync LCD72V 17" LCD...
NEC 1770 monitor
Apr 27, 2008 | NEC MultiSync 1770NX 17" LCD Monitor
AOpen Monitor
It seems a magnatic field effect plz change location or any electric equpment far away to monitor. And if this is window problem then install display driver properly.
otherwise your system in virus effect
Mar 01, 2008 | Gateway FPD2275W LCD Monitor
I cant get the monitors resolutin at 1440x900-60Hz and the monitor keeps going to sleep
your graphics card doesnt support the resolution that your monitors native resolution is set at.
btw, what graphics card are you using?
Nov 23, 2007 | HP Compaq WF1907 Monitor
go into the on screen menu, select the tools menu and you can turn the resolution notifier off.
Aug 12, 2007 | NEC-Mitsubishi Nec Display Solutions...
NEC MultiSync 1760NX 17" LCD Monitor Logo
52 people viewed this question
Top NEC Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a NEC Computer Monitor Expert? Answer questions, earn points and help others
