While in the message drafting window, press menu button on left bottom corner. Select "Add text", and from the pop ups select "Text template" . Then you can see the various templates available. Hope this will be useful. This is the method I use for galaxy S4.
All the best
Edit the HTML template then click the check box in Expand Widgets Template box at top right of Edit Template text box either scroll down OR I always use Ctrl+F type in the code
If you have multiple adsense widgets they will be sequential ie adsense1, adsense2,...... it will be trial and error to find the one you require or you could just align all of them to make it easier.
Open a web browser such as WindowsInternetExplorer by clicking the "Start" button in the lower left-hand corner and double-clicking "Internet Explorer" in the program list.
Display the webpage to be copied, then click the "Edit" tab at the top of the InternetExplorer screen.
Click "Select All" to highlight
the entire contents of the webpage, then click the right-hand mouse
button and select "Copy" from the drop-down menu. This copies the entire
webpage to a temporary memory clipboard.
Open a blank Word document by
clicking the "Start" button, choosing "All Programs," clicking
"Microsoft Office" and double-clicking "Microsoft Word."
5
Click the "Edit" tab at the top of the Word screen and choose "Paste Special."
6
Select which paste option best
suits your needs. For example, the "HTML Format" option will paste the
copied webpage with all hyperlinks, images and text formatting intact.
"Unformatted Text" option will paste only the text from a webpage
without any of the original columns, section dividers or other formats.
7
Click "OK" to copy the webpage into the Word template
There isnt an exact way to add a signature at the end of the txt. In order to do so, you have to create a template with your signature, then insert the template at the end of your txt. However, know that it will count towards the 160 character limit. Instruction from the user manual (pg 38-39) below. Hope it helps!
Message templates When you often use the same phrases, you can save the message under template messages. Adding the message as a template
Press Menu > Messaging > Templates.
Press Options > Add New.
Write the frequently used message > Options > Save.
Sending a message with template
Select the message to send.
Edit the message > Options > Send.
note: You can add a template while writing message. Write a message > Options > Add Template. Choose Text or Multimedia and select the message to add.
Your normal template has probably been edited to double spaced text.
To fix this you need to edit your normal template file - it will live inside C:Program Files/Microsoft Office/ Templates or a folder under this or something similar to this.
Open your template and change the line spacing to single, then save it over the existing template.
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
you can not find the signature because there is know signature that you can put at the end of messages unless you make a template with your signature and add it to messages or you can save your signature into a draft and make new messages from their
try this, select all from the edit menu, then copy, open a new MS Word doc as rich text format, then paste to the new doc and let me know if that worked. it's what I used during MY resume days! good luck!
Not sure what problem you are having with AutoText. One problem could be that you do not have the show autocomplete suggestions checked off. To do this go to Insert, AutoText, then AutoText, and look for the tab AutoText. Make sure the check box marked show autocomplete suggestions is checked off. There can be other parts of the Auto text that is not working for you and you may be able to look around in the other tabs to find the part that is not activated. If you give me more information I might be able to answer a more specific question.
