Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
E1 Error Code
Hi, my husband is trying to locate the cause of the leak in the base of the dishwasher. Do you know what he should be looking for such as common problems??
Regards
Lee
  • Anonymous Dec 19, 2007
    E1 COMES UP ON DISPLAY, I HAVE REMOVED SIDES OF DISHWASHER AND FOUND NO LEAKS... PLEASE HELP
Theres a small filter attached to the hose that connects into the dishwasher. It could be clogged. Clean it out, usually its just muck from the old water.
Thats what happened to us. no wonder no water was going through. and EI was flashing each time water tried to go into the dishwasher.
Posted on May 25, 2008
    Scholar:
    New Friend:
  • 67 Answers
The only parts that usually leak are the motor shaft seal or the fill valve connector. The fill valve seal is usually lower than the motor, try putting in a small amount of water manually and increasing the level until the leak shows up. The device that is then covered in water is the leaker
Posted on Nov 30, 2007
AE comes on. Have not used the dishwasher. Just started today. How do I stop it from coming on. I can call LG tomorrow
The AE or E1 error code indicates a possible leak from the unit. This is most often caused by excessive suds overflowing into the base of the dishwasher.
This problem could be caused by a failure on your machine or the detergent used. I highly recommend you follow the troubleshooting from the LG website. HEre is the link.
LG Help Library AE E1 ERROR CODE DISH WASHER LG
Jun 28, 2018 | LG Dishwashers
Hi. Can you tell me what E1 means on the display
LG Dishwasher Error Code E1 How To Clear
Based on your model number ... it is probably an LG appliance.
Use the link above to learn about the E1 error code. According to the web site ... there is a chance that nothing is broken and the code may have been caused by how the dishwasher was loaded. The web site lists 7 reasons why the E1 code came on.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Dishwashers
How do I reset e1 error code on LG dishwasher after kid puts dish soap in the machine?
The suds may have caused water to run down into the pan under the unit. Take the front kick panel off and look for water under the unit and in the catch pan.
Jul 01, 2017 | LG Dishwashers
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
The error code is Thermistor/when/thermistor module failed
Hello patbauns - Typically the turbidity sensor, or thermistor, is located in the base of the unit. If water is leaking from the door, it is possible that water has made its way into the base of the unit and potentially shorted the thermistor. At this point, I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Mar 07, 2013 | Electrolux 24 in. EDW5505EPS Stainless...
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
LG Model 67LDO210 Error E1
Hi, the "E1" error code means the dishwasher has developed a leak. Meaning your outlet hose is too low or too far down the drain, it is losing water while it is washing making it think there is a leak...
Jan 16, 2011 | Dishwashers
I have error code e1
Hi. Sorry this is so late, but I just happened across this post, so I thought I'd see if you have solved your problem yet. The EI code most often is caused by water leaving the tub during the wash cycle. The most common cause of this is that the dishwasher drain hose does not have a high loop in it. Often, the installer ran the hose right down through the floor. It needs to loop up high before going to the drain to prevent water loss, and a resulting IE code.
Oct 25, 2008 | LG LDF6810 Built-in Dishwasher
Leaking dishwasher
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Feb 02, 2008 | Dishwashers
"E 1 code error
The fault is that the anti flood device is activating, you have a leak somewhere in the base of machine. Regards Engineer
Aug 05, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
268 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
