Question about JVC XV-511 DVD Player
JVC XV-511 Audio OK with CD but none with DVD
Audio OK with CD but no audio with DVD.
  • Anonymous Dec 16, 2007
    Same problem. Audio fine with cd but nothing with dvd.
  • walkshaunt Dec 18, 2007
    Actually, Fixed the problem by going into the on-screen display and changing the Digital/Audio Output Preference to Stream/PCM.
The reset worked fine for me...I only unplugged it, then held in the Play and Open/close buttons...then I powered it on and off, then on again...works fine now!
Posted on Aug 31, 2010
Walks' solution worked for me! Thanks lots! I was about to head to the repair store!
Posted on Aug 18, 2008
Had this problem for a year. Finally fixed it last night with the reset code. Unplug unit, hold the open/close and play button down while replacing the plug. Test JC3 will appear in the display. Release the buttons and press the 3D Phonic button and 9600 should appear in small numbers under the Test JC3. Turn the power off and back on. I had to do this several times and the last time I pushed the 3D Phonic button and then the play button but it restored the sound to the DVD.
Posted on Dec 18, 2007
Only getting background sound with dvds
This problem could be related to your DVD's audio settings.
1. Check that 3D Phonic is turned OFF.2. Navigate to the Preferences menu3. Select the Preferences 2 tab4. Select "DOWNMIX" and change it to L0/R0
Manual
Oct 28, 2012 | JVC XV-511 DVD Player
When I insert a DVD disc I get the message "cannot read disc". The DVD player will play an audio CD but not the video. DVD player is a JVC Model #XV-N320.
Good day. The message your getting only tells you that the Dvd your trying to play have a lot of scratches already that makes it unreadable for your dvd player. You can try to wipe the dvd first then try it again. If it doesn't work then that means the dvd unusable. Hope this information help a bit in resolving your question. Thanks for using fixya and have a great day
May 25, 2011 | JVC XV-N320 DVD Player
How to unlock jvc xv-thg41 dvd
hi How do I unlock my JVC xv - THG41 dvd player
Sep 29, 2010 | JVC Audio Players & Recorders
The video of my jvc dvd player won't display on my tv screen or the video is not working but the audio is ok.
Connect the yellow connector on the DVD player to the yellow connector on the TV. Refer to the TV manual and select the video input. Refer to DVD manual and choose interlace on the DVD player. Let me know if this helps
Jan 13, 2010 | JVC XV-N322 DVD Player
DVD remote Codes for a JVC XVN332
jvc xv n332 audio ok but no video how to unlock
Jan 01, 2010 | JVC XV-N332
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
Progressive light on have audio but no video
Look at the Audio Menu on the DVD, it is possible with the remote control to push the MUTE button while going back.
Look at the MUTE button on the remote and push it again.
AL
Dec 24, 2008 | JVC XV-N40BK DVD Player
Automatically lock???
ATTENTION Opening your player will void the warranty! Modification are at your own risk! No guarantee for function!
JVC XV-511
selfmade hack
1. Remove the top cover. 2. Locate wire jumper B532 o the printed circuit board nearby the front panel, it can be found just underneath the connector linking this board with the one above. 3. Cut bridge B532. 4. Apply power, PW (Password) appears on the display. 5. Enter the code 5963 with the remote controller, PW OK will be displayed. 6. Switch the set off and on ... and it will be zonefree !!!
Important information It seems that JVC received some complaints from the software industry that these players were much too easy to modify and they had to change the design to prevent further 'multi-zoning'! All sets with a serial number starting with 134xxxxx or 144xxxxx will normally need a new PROM to make them a real multizone machine! Don't despair if you have one of the newer types because there's a hidden multizone 'backdoor' ! Yes, the above mentioned modification will still work after you plug in the power cord, at this moment the set will play all zones as long as you don't switch it off with the standby button, once this happens it will be back to zone 2 and you'll need to unplug/plug in the power cord again to get it back to multizone. ATTENTION Opening your player will void the warranty! Modification are at your own risk! No guarantee for function!
Dec 15, 2007 | JVC XV-511 DVD Player
JVC XV-511 DVD Player Logo
245 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
