Question about Fujitsu Siemens Siemens (S26361-F2378-L30) Internal DVD Drive
Fujitsu seimens I plugged in and the tray opens and has power but now my cd-rom drive doesnt show up or read cds and the dvd drive doesnt show up but is detected and says new hardware is installed and device manager says its working normally . Im not sure how to get them working an the software on my disk to help me cant be read now either
  • azamanpour Dec 10, 2007
    the device manager show that the dvd drive work properly , but it can not reed any dvd or cd. i don't now if it's damaged or is it a problem that can be solved. the model is Amilo M7405
  • Anonymous Mar 18, 2008
    My issue is that it will not burn DVD's only CD's. The problem also started in November. It seems that the DVD drives are not designed to last longer than 3 years, Even though I have not burned a lot of CD's, let alone DVD's. Anyone know where can one get a replacement?
AvioriX
  • 689 Answers
SOURCE: power calibration area full
There are many facts cause "Power calibration area Full" error. First of all clean up your TEMP files. Make sure DVD media you are using is supported by you DVD Writer. CDs are rather easy to write. DVD requires more precise laser beam to channel as its more dense than CD. So physical facts like dust on the lens might be a factor too. Also firmware update for your DVD Writer will be a great step. These are the main factors.
Good Luck
Posted on Dec 30, 2007
jimbo6
  • 89 Answers
SOURCE: No sound
Windows XP OS?
Posted on Jan 10, 2008
tat4u
  • 520 Answers
SOURCE: fujitsu siemens 8830
check to see if lid switch is functioning correctly if possible.
if **thing seen,** change ,inverter board needs replacing.
you've tried changing moniter so it isnt cable connections internal or external.
you're **t hearing any beeps so it isnt video,mem or hd.
Posted on Mar 10, 2008
confoxer
  • 55 Answers
SOURCE: Dvd drive not working on amilo pro v2030
my first suggestion would be to take it in to be repaired professionally, but if you can't then, taking it apart would be risky especially if you are carrying a static charge (one zap and you will be searching for MORE replacement parts or a ENTIRE new computer) one way to avoid this is to use special tools and non static clothing (eg don't wear your favourite fuzzy slippers or big woollen shirt or work on a carpet!). Best bet is to just send it in.
Posted on Aug 13, 2009
Tech4less
  • 35 Answers
SOURCE: problem with fujitsu laptop esprimo v5535
I suggest doing a manual reset, and if all fails start by removing certain hardware equipment such as memory, wifi cards, etc. If you need more info, please ask.
Posted on Feb 07, 2010
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer...
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Regards,
fossildude
Mar 15, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
Fujitsu Seimens Scenic C600, how do you remove CD Rom
If you press the disk eject button on the front of the CD ROM drive and it doesn't eject the CD. Then try right click on the CD drive icon and then click eject.
If this doesn't work, then straighten a paper clip and insert it into a small hole on the front of the CD drive just below the CD tray and push the paper clip gently and the tray will pop out slightly, then you can grab it and pull the tray out to get access to the CD.
Sep 20, 2009 | Fujitsu Siemens SCENIC C600 PC Desktop
My new dell laptop does not recognise any cds/dvd i put in
i am having the same problem with my fujitsu siemenbs laptop and i can see a CD/DVD icon but it just doesnt ecognise any dvd-w or dvd-rw only cd's what shal i do?
Sep 18, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
PC will not read CD's on DVD drives
my acer 4520 cd rom is not working well when i press cd roms butten its not *** out & also in my computer its tht cd rom icon is not showing so plz give me the solution asap....
Jun 23, 2009 | Acer (91.AB264.001) CD-ROM Drive
Toshiba cd-r/rw drive reads but doesnt write
I checked out the specs for that drive.It only reads dvds/cds.
I see that it has no cd/dvd writing capabilities.
All the cd's you used may still be blank
Do you have another drive you can try out?
Jan 26, 2008 | Computers & Internet
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
DVDRW will not read CDs
1)right clik on my computer
go to
properties
device manager
clik on cdrom
uninstall it then re-install it
after reinstall try using the drive
2)update windows ,use custom and see if it finds an updated driver,if it does or doesnt update windows anyhow.
after you restart the computer try using the rom drive.
if that doesnt work;
go buy a cd/dvd rom cleaning disk at your local electronics store and use it.
if all this doesnt work;
buy a new rom drive
Dec 08, 2007 | Computers & Internet
DVD writer, master drive
If you have both the DVD and CD drives connected to the same ribbon cable you want one set to Master and the other to Slave, or both set to CS (cable select). Good luck.
Nov 10, 2007 | Computers & Internet
Teac DW-224E CD-rw/ DVD rom in Toshiba Satellite Pro M15-405
Hello konagold, Yes there may be some ways to test it. Let's try the following. When you open your laptop, open the cd rom's tray and check to see where the lens mechanism is positioned. Normally it should be near the main central motor. Try to turn off the laptop, but leave the tray opened. When the laptop is turned off, use one one hand to move the lens assembly away from the main motor. Move it to the middle of the distance from the center to the edge. Carefull not to touch the lens when you do this. Now place a bootable cd (like the ones that come with your operating system or anything else you can find) and start the laptop back again and instruct it to boot from the cd-rom. It should make it try to boot from there. If this fails, the cd-rom is indeed damaged and most likely will need to be replaced. You may try to clean the lens assembly but I can't be sure this will help, based on your problem. Please run these instructions first, then reply to me in order to see what's next to do. Bogdan
Jul 30, 2007 | Teac (DW224E/S) CD-RW/DVD-ROM (Combo)...
Fujitsu Siemens Siemens (S26361-F2378-L30) Internal DVD Drive Logo
46 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
