Question about JVC GR-D70EK Mini DV Digital Camcorder
Viewfinder on digital camcorder doesn't work
I kept getting a lens cap error on my viewfinder and it doesn't display any picture whilst recording. Works fine on playback, any ideas?
  • Sivco Nov 29, 2007
    I too have the same problem with my GR-D53EK...any ideas to correct?
Thanks kstahly, contacted JVC shortly after my original posting and they have been superb in dealing with this issue....extended my warranty conditions to cater for this problem......even though my camcorder was purchased in 2004!!!.....now that's what you call customer service!!
Posted on Dec 28, 2007
    Novelist:
    Scholar:
  • 53 Answers
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
    Sergeant:
    Champion:
  • 231 Answers
Camera possibly needs a new CCD imager on lens .This is very common .Other possiblities are ribbon cable loose on imager boards .But most probable is a bad CCD imager on lens.Unit needs repair
Posted on Nov 29, 2007
SOURCE:
No picture from lens; playback ok; lens Cap
CCD (imaging IC) went bad and has to be replaced.
Nov 14, 2009 | JVC GR-D20EK Camcorder
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Apr 01, 2008 | Video Cameras
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Sony DVD92 LCD/Viewfinder doesn't display image
I had this problem and called Sony. Apparently there was a problem with handy cams and they paid to fix it.
Dec 17, 2007 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
NO PICTURE ON LCD SCREEN OR VIEWFINDER
model # is required for me to help you.
Sep 09, 2007 | Canon DC10 DVD Camcorder
No visible picture in camera mode
Hello Kenza, replacement of CCD that belongs to Lens device. Please contact your nearest Samsung Service. Best regards, Arpad
Sep 04, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Sep 14, 2005 | Sony DXC-190 Camcorder
JVC GR-D70EK Mini DV Digital Camcorder Logo
75 people viewed this question
Top JVC Video Cameras Experts
Ekse
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
