We have a great picture on our Toshiba TV, but no sound!
We have a great picture on all our cable channels. However we have no sound at all. At first there was sputtering and then nothing. How can we economically fix this problem. The TV is only about 2 years old.
Re: We have a great picture on our Toshiba TV, but no...
Recheck all the cables connections,and might replace all the cables,if not solve ur spechker
have cold soldier connections joints or short or
dead all together in ur tv.
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
I uncovered the problem. The "analog tuner" seems to have gone bad. The part is $25 -$36. The set can still be used however. I just removed the coaxial cable from ANT 1 in the back of the TV (this is what I believe has become defective)which was going to a VCR. I then just used composite cables(red,white,yellow)to bring the signal directly to the TV from the cable box, rather than the VCR. All works however, will replace the defective part.
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
