Question about Philips 20DV6942 20 in. TV/DVD Combo
Dvd not recognaizing the disk
Cleaned the lens as advised but didn't help. Problem is stll here.
Can u help Plz?
  • 3 Answers
Sometimes it is only to change the engine of draft, but in others it is necessary to change the lacer, it checks also the tape that tunes in to the lacer
Posted on Mar 01, 2008
Hi i hav downloaded ea cricket 2007.while installing the game in cd:1 after loading upto 33% 'a problem occurred while trying to transfer a file audiopbp.big from media'?it is asking to retry but no...
There could be several reasons. Either you cd/dvd drive's lens has to be cleaned, or the cd is in bad condition. Try copying the installation files to the hard disk and then install the game.
Nov 07, 2009 | EA Sports Cricket 07 for Windows
Dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Apr 07, 2009 | Televison & Video
Panasonic DVD-S35 Player H02 problem
Hi, this is an unfortunate error. this is referring to the lens assembly. it is unable to scan and read at this moment. it could be because the lens is dead or, it could be that the lens is simply dirty and will need to be cleaned. i would try cleaning it with a non brush type cleaning process. Once cleaned and you still have the same issue, i recommend replacing the lens assembly.
Mar 11, 2009 | Panasonic DVD-S35 DVD Player
No disk inserted
you could have a dirty laser lens try a lens cleaning disc. if that does'nt work you have either a bad laser or spindle motor.
Feb 13, 2009 | Philips Magnavox MWD200G DVD Player
VCR will play, DVD returns disk with"check disk"-will not accept
Dirty or defective laser lens. try manual cleaning of the lens if you know how to open the unit top cover. manually clean the lens using cotton swab gently rubbing it in circular motion. blowing of air to remove dust will not really help clean the lens.
Jan 03, 2009 | Samsung DVD-V4600 DVD Player/VCR
Samsung v5500 dvd combo problem
When you get a whirring sound, some click and disk not engaging on some disks, and not others , that is because lens cannot read the inital track on the CD/DVD.
This is either because disks are scratched , dirty or ruined by light and heath, or because the lens is dirty.
Try using a lens cleaner like the ones here.
If that does not work, then the unit must be taken apart and the lens cleaned with cotton buds and isopropyl alcohol.
See :
How to Clean the Laser Pickup Lens on your DVD Player
Jan 01, 2009 | Samsung DVD-V5500 DVD Player/VCR
DvD player no disk
hi most of the time a cleaning disk is not enough, you have to open your dvd player and clean you laser lens whit a cotton swabs and alcohol do not use peroxide. Do it slowly and be careful
Nov 29, 2008 | Televison & Video
Dvd disc won't play
Maybe the laser lens are dirty and need to be cleaned
Nov 04, 2008 | Samsung DVD-V5500 DVD Player/VCR
Toshiba sd-310vu dvd player makes noise and says disc error
The motor that spins the disk rests on rubber shocks. The rear shocks wear out over time allowing the disk to set uneven and rub eventually stopping the disk and giving a disk error. To fix simply put one small flat washer under each of the rear shocks this will level the motor and stop it from rubbing.
Jul 02, 2008 | Toshiba Televison & Video
Help
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Oct 28, 2007 | Symphonic WF803 DVD Player/VCR
Philips 20DV6942 20 in. TV/DVD Combo Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
