Home | Maytag | HYE3658AY Electric Dryer | One of the baffles bro...
Maytag HYE3658AY Electric Dryer
Problem for Maytag HYE3658AY Electric Dryer
One of the baffles broke off the tumbler and need to replace it
By nreeder on Aug 13, 2009
I am not sure how much of the Maytag dryer mde3500 needs to be dismantled to get the drum out and screw in new Baffle. Do I need a major repair guy or can I figure it out on my own. It is not an electric problem just a screw in one so should not be impossible...right?
Comments:
Aug 13, 2009
- I will give it a try. Hopefully don't run into any trouble getting front and top off. Ordered new baffle and waiting for part. Not sure size of screw to buy yet either. Suppose once take all apart I can use the old one to match it. Thanks
Solution #1
posted on Aug 13, 2009
Not Rated)
advanceda76
Rank: Guru
Rating: 89%, 31 votes
correct no repair guy neede unplug the unit so you dont get electrocuted happen to me once dont let it happen to you. remove the front panel than undo two screws at top of cabinet to release the top rotate the drum so the baffel you are replacing is at the 12 oclock position insert the baffel rub the screws thru the factory holes at top of unit if the holes are stripped dont be afraid to throw a washer in with the screw and dont over tighten because they will stripp out the plastic baffel . reasemble and your done takes about ten minutes
Was this helpful?
Yes
No
Popular Solutions for Maytag HYE3658AY Electric
Questions and Unsolved Problems for Maytag HYE3658AY Electric
Do you recommend Maytag HYE3658AY Electric Dryer?
Answer
Answer
my maytag dryer wont start and the drum light doesnt work anymore. what is the problem? dryer is... (More)
Answer
where are the thermostats located on this dryer?
Answer
Hi! I have a Maytag HYE3658AY and it shut off in the middle of a load of laundry with no warning. We... (More)
Answer
I replaced the element to find that it was not bad , so I replaced the thermostat on the element... (More)
Answer
My dryer is not working, when i tryied to turn it on. I got it zapped me. I looked for burnt wires... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag HYE3658AY Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
