Question about Garmin GPSMAP 295 GPS Receiver
Street Map Program for Garmin GPSMAP 295
I recently purchased a used GPSMAP 295 for my airplane and am wondering if there is a software program I can acquire that will give streets and mapping programming for use in my RV when holidaying. Need Canada and US map programs. What is compaitible and where is a good source for same?
    New Friend:
  • 15 Answers
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Posted on May 06, 2010
SOURCE:
Where do i go to down load update for my gps 295. garmin said thay dont support this unit. thanks joe
Joe,
The Garmin "GPSMap 295" is at, as far as Garmin is concerned anyway, "end of life". This means Garmin will no longer support, repair, etc. this product. C'est la vie.
Garmin's older product lines lack the hardware to decompress the new "NT" (New Technology) maps that Navtek (the map company) is producing now. The NT maps are compressed so that they would fit on smaller capacity memory cards. By doing this, the maps required Garmin to include hardware (special designed circuitry) that could quickly decompress these maps "on the fly" for display. The much of Garmin's older GPSMap & StreetPilot lines predate this hardware requirement.
Our "still-functioning" GPSMap & StreetPilot GPSr will still pinpoint our location on the Earth as always - but lack the latest & greatest maps. You should review the maps that your GPSr can use and choose the one you prefer. I switched mine to display topographical maps. These show many of the road names like the City Navigator maps do, but lack important things like the POIs and routing. If you can do without them, this could be good enough. If you can't, you'll need to decide on whether the last non-NT map version is sufficient or purchase a new GPS that can accept the maps you want to put into it.
I hope this helps and good luck!
Sep 06, 2011 | Garmin GPSMAP 295 GPS Receiver
Unfortunately deleted the maps suppled withe the device.Hve obtained the basemap and sum file on dics from garmin and have loaded it to the device however the maps are not showing up.Have downloaded...
When reinstalling the maps to the unit, use the program Map Install from garmin. If you did and still cant find your maps, call garmin back and have them remotely access your PC. They will be able to fix your issue.
Hope this helps!
Feb 12, 2011 | Garmin GPSMAP 62s GPS Receiver
GPSmap 76CSx is not acquiring satellite
Update the unit using Garmins WebUpdater program, this may fix your issue as there was a chipset update that is crucial to acquiring satellites. here is a link to the software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 07, 2011 | Garmin GPSMAP 76CSx GPS Receiver
How do upload updated maps to my garmin660
go on garmin, connect your gps via usb , get map install program and you should be fine, works on any operating system
http://www8.garmin.com/support/mappingsw.jsp
Jul 01, 2009 | Garmin Nuvi 660 GPS Receiver
How to Transfer Maps to GPSmap 60csx
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
May 01, 2009 | Garmin GPSMAP 172C GPS Receiver
Does Garmin GPS 295 contains Maps for Africa and the Middle East
Hi there -
The GPSMap 295 can only have one region at a time - North America, South America, etc. You can purchase an updated database specifically for Africa and the Middle East - it's about $50 USD. It will erase whatever region you have in there right now (you can't store Africa/MidEast with America, for instance. It's one at a time.)
The Garmin Website:
http://shop.garmin.com/aviation/databases/
lets you download new Jeppesen databases to your GPSMap 295. Select your model, then select which region you want.
***Before you buy:*** You'll have to have the data cable to connect it to your computer. Without that, you will have no way to update the maps and database.
If you do have the data cable, the process is very easy - just follow the instructions carefully, and make sure all the numbers they ask you for are correct. I just did mine today. Good luck!
Mar 24, 2009 | Garmin GPSMAP 295 GPS Receiver
Have problems with the loading of the map XPC415S. Australia East coast. Will this map work with this unit?
Any bluechart that has been preloaded on an SD card should work.  Did you purchase your chip with the data preloaded or did you download it yourself?  If you downloaded it yourself, try erasing the sd card, format it, then insert the blank card in the 420 and power it up. This somehow preps the chip for the data download.  Then download the bluechart onto the chip and try again.  There is some ambiguous wording in the download screen that makes it look like some kind of error, try the download anyway and most of the time it will work. After the download is complete it should list the bluechart software version on the screen along with some other software info.  If the operating system software is not v2.5 or higher, you may need to download a software update first.
Oct 25, 2007 | Garmin GPSMAP 420s GPS Receiver
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 295 GPS Receiver Logo
269 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
