Question about iRiver H10 MP3 Player
My H10 will not connect to my computer
A friend of mine bought an H10 a little while back but only used it a handful of times. Recently, I bought it from him, but I am having trouble connecting it to my computer. I plug in the USB cable to my H10, and I get nothing. It connected the other day just long enough for me to add a "test" track and since then, I have not been able to get anything from it. I spent almost six hours the other night trying to troubleshoot it, but I have not had any success. Is there any particular reason why my computer is not noticing my H10? Is there anything that I can do to fix this, or is it just my computer?
  • 1 more comment
  • Khonshu Nov 29, 2007
    My friend didn't have anything software wise that would have come with the H10. Is there any program that I need for my computer to recognize the device? I went to iriver's support site and downloaded iriver plus, but this did no good. I also tried to dowload firmware, but nothing was happening when I opened the zip file. I am at a loss and am quite frustrated as I was looking forward to using this product..
  • Tony Hernandez Dec 26, 2007
    My iriver h10 won't boot up
  • kevin2209 Apr 01, 2008
  • 8,596 Answers
The iRiver website has the software - just enter your model number, go to the support section.
Posted on Jun 13, 2008
SOURCE:
I have just recently bought a second hand PS£
Ohhhhh u got there a problem i had months ago. PS3 only gives u one output signal at a time, that means either u use it hdmi or u use it the normal rca way.Bad thing is that the ppl at sony didnt think of this kind of situation.
What u need to do is go to ur friend's house and use his hd tv to config ur ps3 to the correct output signal(rca), both on video and audio. If u bought the ps3 from ur friend, he should know how to do it, since he had to config it to hd in the first place. Be sure to probe it with the config u are going to use at home :)
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
How to reset my iriver H10 to factory defult
There is a small hole on top of the player it says reset beside the hole. You need a small straight pen to stick inside and press down you will feel it click , then restart your player.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 28, 2009 | iRiver H10 MP3 Player
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
SYSTEM FILES MISSING
I had same problem. On this website I read that problem is due to hard drive malfunction. I have solved my problem by doing the following. Actually a friend of mine told me he solved similar problem with his iPod this way.
1- Per indication on this website (fixya) I put device next to my ear at the time I turn ON and screaky sound was present. In my case I could hear that sound.
2- on a solid table I put a piece of cloth
3- removed batery from H10 and installed back ON (I think this is called reset)
4-put iriver h10 on my hand with screen towards my palm
5-turn device ON and immediately slap it against table (with piece of cloth in between) at third attempt device boot normally.
I figure, device was dead why not try this. In my case it worked.
Now I am trying to synch my music. sometimes it sync sometimes it reports error but music is there.
Oct 11, 2008 | iRiver H10 MP3 Player
1080i question for PT5598HD
the best from what i seen is HDMI, DVI, or comp. in that order.
On my 82" HDTV i use the VGA plug connected to P4 3.5ghz.
everything seems to come to life using a computer and good video card.
Nov 29, 2007 | Akai PT5598HD 55" Rear Projection...
REPAIR OF IRIVER H10 20G
Try rebooting the little hole next to the lock with a pen or something similar mine works everytime
Nov 16, 2007 | iRiver H10 MP3 Player
IRiver H10
You have all posted different issues into one forum - bad idea.
For the laptop people - many laptops have USB ports that do not have enough power to drive/charge an Mp3 player - must use USB 2.0 ports.
"HD Audio Bus" guy - go here for the missing driver: Go to Microsoft's own site, and try the hotfix/driver:
http://support.microsoft.com/kb/835221
Woest - Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Nov 15, 2007 | iRiver H10 MP3 Player
Downloading from my camera through my port
A friend of mine was having the same problem and come to find out, she was going onto the Kodak website to transfer the pictures. I told her that she doesn't have to do that, just press the button from the dock (sometimes you have to hold it down for a few seconds) and a box opens up in the right hand corner on your computer screen, click transfer all. sometimes I have to play with it a few times for it to go. I have had the DX6440 for almost 5 years and have had good luck with it. As a matter of fact, I love it. I recently bought an Olympus E-Volt 500 and I like my little Kodak better, especially for close ups. I hope maybe this solution will help, I know it did help my friend. She was going crazy and that's all it was. Now my Olympus, I have to transfer from the site. Hope this helps!
Nov 13, 2007 | Kodak EasyShare DX6440 Digital Camera
Iriver H10 "System files missing".
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
Sep 22, 2007 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
143 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
