my monitor powers on with a dark screen for first two minutes then comes on with no problem. when left off for more than 5 hrs. It repeats the same problem. the problem has esculated with screen remaining black for the first 2 to 4 hrs. of being turned on before showing. I was told by a monitor repairman that the problem is with the power module and it can be repaired with a estimate of 156.00.
Could be the power module or the backlights (more likely backlights if the "luminance" varies)- $156 sounds a little high but not insane, but you realize cost of replacement is lower, do you not?
Was this helpful?
Yes
No
Popular Solutions for HP vs15 15 in. Flat Panel LCD
turn if on picture shows and immediately goes black. turn monitor off and then on again. picture...
(More)
turn if on picture shows and immediately goes black. turn monitor off and then on again. picture shows and goes black.
HP 15" LCD monitor model PE1233 - powers on then off then on then off etc. Is it the...
(More)
HP 15" LCD monitor model PE1233 - powers on then off then on then off etc. Is it the bulb/inverter or is the internal ac transformer?
