Question about Sharp AL 1631 Copier
Flashing 4-H error message
Copier will not work and keeps flashing 4-H
    Novelist:
  • 208 Answers
Try this reset procedure. Most likely this will work.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 13, 2007
  • bigguyc9 Sep 20, 2010
    Worked exactly as you said. Thanks
    New Friend:
Trickieone was correct about how to fix the flashing "4H" on my Sharpe copier. Thank you so much!
Posted on Jun 28, 2010
  • 32 Answers
Fuser error - needs a tec - heater lamp, thermal fuse or thermister is broke. I would go to a tech for this problem..
Posted on Nov 29, 2007
SOURCE:
My canon copier D420 had a paper jam. can't get the copier to work now.
Try checking the paper path, there might be a broken or loose gear in there, a bent wire or stuck debris. If you done this and all seems ok but the error message keeps flashing, try to do a hard reset. That usually clears off error messages. If nothing happens, you might need to call a technician.
Feb 07, 2013 | Canon New Usa Imageclass D420 Laser...
Flashing message "service needed" code
That is a jet stack heat error.
Most likely problems
Bad Ink Loader
Bad Print Head
Bad Pre heater.
The Left Jetstack is drawing less power than expected. My guess would be a bad printhead.
May 18, 2011 | Xerox C2424 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Error message DC1560
This code shows that paper feed is jam in left side.just check any paper is jammed in this side.or sensor liver is pressed in paper path.by MIAN JEE
Nov 17, 2008 | Kyocera KM-1505 Copier
I had the error message L-4 .can you halp to fix this problem?
L6 is a laser polygon motor fault, you need to replace the polygon motor in the laser unit, but try the reset code first sim 14
May 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL 1631 Grayscale Copier Problem
Have you tried removing all cable connections on it and turning printer off and unplugging it from power supply and powercycle?
Apr 29, 2008 | Sharp AL 1631 Copier
fuser error - needs a tec - heater lamp, thermal fuse or thermister is broke. No simple fix
Oct 30, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
642 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
