DVD help The door to the DVD will not open. Is there something I can do to open the door. It's the DVD for the TV. It's doesn't have a hole for a paperclip.
  • 83 Answers
Well, it has to have atleast a crease in it for sliding, but sticking back there either a disk is up or it was jammed back, I would get a thing blade sicors or screw driver to pry it open, or call somebody to do this, and if you can't seem to do this you have'ft to replace it :(
Posted on Nov 29, 2007
  • 32 Answers
Can u tel me the brand and model of the DVD so that i can assist you further..
SOURCE:
How do I open the DVD?CD drawer?
you will find by the door as a very tiny hole if you use a safety pin or something similar that is small enough to fit through the hole it is meant to open the door
Jul 14, 2014 | ASUS Computers & Internet
I recently purchased a Toshiba laptop, model #S855-S5254 . I am unable to open the door to the DVD player. Does anyone know if there is a lock on it, or how to access the "unlock" if so.. Please help
If the eject button doesn't open the door, try going into 'My Computer', then right-clicking the DVD drive, then click 'Eject' on the menu that pops up. Maybe that will get it open for you.
Dec 14, 2012 | Toshiba Satellite S855-S5254 Laptop
The door will not open.
It may be jammed. There is an emergency release, though. Look for a tiny hole just under the tray. Insert a straightened paper clip or something similar into the hole. The tray should open.
Jul 03, 2011 | Sony DRX840U DVD-RAM Burner
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Hello
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
Apr 24, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
This is a dvd recorder for a tv the door door to yhe dvd will not open
sounds like something has jammed in the drawer track
on the front of the drive is a very small hole
that is the manual open override
use a paperclip and push it into the hole as far as needed until the drawer opens
then slowly open the drawer by hand
look on both sides of the drawer to make sure there is no dirt or other foreign matter in the tracks where the drawer opens
Dec 16, 2010 | Lite On LiteOn 16X Dual Layer DVD...
It just won´t open, i think is something mechanical because when i insert a paper clip in the eject hole y doesn´t open either. Help please, how to fix it. Thanks in advance
I would turn the computer off the try a paper clip. You may need to "feel" up or down to find the ejector too (or press a bit further). Or, lift up gently on the drive door when you try to open it.
Oct 18, 2010 | Sony DW-G120A DVD RW Dual Layer Burner
We have a Audiovox KLV3913 under cabinet tv/dvd combo that has a DVD stuck in it. Push the open/close button & "Open" shows on screen but door never comes open. No longer have manual & couldn't...
There has to be a small hole at the front of the door where u will be able to insert a paper clip and press then dvd shud eject. If not open door with a paper clip and manualy pull the drawer outwards, though be careful and do it slowly thus not damaging the gears of the ejection system. hope it helps. regards.viv
Dec 23, 2009 | Audiovox KLV3913 12 in. LCD TV/DVD Combo
The screen faded to black. Followed by a humming noise, and a burning smell. Now the T.V. won't turn back on and the DVD is stuck inside.
Probably something shorted out in the power supply. Sadly these days small TVs are cheaper to replace than to repair. To remove the DVD look for a small hole on the DVD tray door. Straighten a medium sixed paper clip and push into the hole and the DVD tray should release and open. Remove the DVD and toss the TV.
Sep 23, 2009 | Coby TV-DVD1350 13" TV
THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE
tere should be a little pin hole somewhere on or near the dvd player. take a paper clip straighten it out and put it in the hole you will have to push hard until the dvd holder pops out a little then pull it out until it stops. remove the dvd and push it back in then try to open the slot using the open button. it it doesn't work then you will need to take it in for repairs or replace the tv. though it would probably be cheaper to replace the tv.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Emerson EWL20D6 Television
I cant get the dvd tray to open
in the corner of you dvd door you will see a litle hole push there with something who can enter there and your door will open no need power for this operation
Dec 10, 2008 | Televison & Video
56 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
