when in spin out cycle when first comes on makin a noise like something is in the pump i check it and the pump is clear must be maybe lower bearing assembly sounds like something is lose or broke it also stops instancely at end of cycle what could this be
You need the drum wheels and/or the wear pads replaced. If you continue like this, you will make more damage and the cost will be greater. Repair it while your at the warning stage. This involves completely opening the unit and removing the drum. If not up to it, call an expert. goodluck, Macgivor
there may be a sock or something that got in the out skirts of the dryer lip in side the dryer door either that or the main bearing is gone and you need a new dryer. hope this helped
When I first got my PS3, It had the annoying high pitched fan sound as well, but went away after a week and has worked fine ever since, no problems at all. I have the 60 gig version, so. Maybe if yours is new you just need to break it in?
the sound is like somebody is scratching a drum and banging it too
If you would describe the noise it makes, it would help make a diagnosis.
