Probably your inlet pipe is clogged, or not open sufficiently. Plug off the wall, turn off the inlet pipe, disconnect tube to check carefully if anything is blocking the fine screen on both sides of the pipe. Also check the machine screen where water comes to the machine. It is good to close the inlet valve after your washing is done.
Rate me pl.
i had a repair technition come by and he said the inlet to the pump was blocked and he cleaned it out and flushed the pump. he said it was probably due to a build-up of too much detergent and said i should be using half the detergent i have been using and buy a brand that has the "h.e. high efficiency" label on the detergent. thanks for your response!
I have a Fisher Paykel Smart Drive washing machine. I know nothing about them. It's filling with water. Just comes out in a dribble out of the cold side. I changed the hot and cold pipe over cos the hot side was working fine and selected the hot setting, but had cold coming through. The washing machine now beeps at me. Do I need a new cold side 12V relay? Regards, Sam.
