Question about Motorola Mobility RAZR V3
Missing Hinge Pin
One of the hinge "pins" (the silver pieces that hold the hinge together) fell out of my phone. Where can I get another one???
    Scholar:
  • 181 Answers
EBay! You can find all parts there.
Posted on Dec 06, 2007
SOURCE:
2005 yamaha sx230 boat center window hinge pin need to be replace
Normally everything for Marine use is Stainless Steel. Iron rusts away too quickly!
Take the hinge off the boat and drill the old pin out. Fit a new pin. Stainless welding rod is possibly the correct size if you cannot fins a stainless pin.
Apr 18, 2016 | Computers & Internet
Tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
On my Kitchenaid Artisan mixer the 3" silver rod fell out the back. How do I slide back in?
I an sorry but the only Rod in the back of a K45SS is the pivot hinge pin that holds the motor head onto the base. if it fell out then the answer is simple. Turn the mixer upside down and wiggle the base while sliding the pin back in. Once the pin is back in place, there is a set screw in the middle of the shaft that you can see while you are replacing the pin, turn this back down with a flat head screwdriver untill it is firmly against the hinge pin. The culprit of the problem is this set screw. It came loose and allowed your hinge pin to vibrate out and then fall down or fall out as you said. once the set screw is back in place you will be fine. To avoid this problem in the future you might remove the screw entirely and put a drop of "Lock-Tight" on it that will help hold the setscrew in place for a very long time.
Dec 11, 2012 | KitchenAid K45SS Classic Stand Mixer
I am a female and putting together my first bbq....how does one attach the hitch pin to the hinge pin.....urrrrg
Hi stephlive4u...
You will remove any clips,pins,etc from the pins you will be inserting into the hinge holes of the grill.
Have someone hold the lid and you align the holes of the hinge together from the base and lid.
After they are aligned then you will insert the pin into the aligned holes and insert or clip on the retaining clip,pin,cotter pin,etc on the end of the pins you just inserted to lock them into place and to keep from losing them.
Please take time to rate me
Sep 01, 2011 | Char-Broil CharBroil 4637318 Grill
How do you reattach the door to the stainless steel mini fridge? I kinda hit it and it fell off.
you will need to lift the cover from the top hinge loosen the approx 3 screws holding the hinge on do not remove completely just enuogh to allow door pin to be reinserted in the hinge then close door and tighten hinge
Jan 03, 2011 | Sanyo Refrigerators
How do i install the keypad with flex cable throught the hinge on a v3?
There are small screws on the silver end pieces that hold the 2 pieces together. You have to completely take the phone apart top and bottom take the end piece out of the hinge and very carefully slide the flex cable through. Go to HowardForums and look for a tutorial there.
Aug 05, 2009 | Motorola Mobility RAZR V3
"Bolt" replacement on Razor Phone
Be very carefull with the phone. The main cable runs through that left side.
Look on Ebay for a Left hinge pin for the V3. Also knows as the left knuckle.
Make sure you look for the V3. Not Razr.
If your speaker goes out, or you lose display before you get the Knuckle, you need to get a keypad flex also.
If not, get the Knuckle, and it just slides in. MAKE SURE before you pop it in that there are no pieces of the old one in there and that you don't pinch that cable.
I can fix it for you if you send it to our business, but if you're careful, you shouldn't have a problem.
Jul 31, 2008 | Motorola Mobility RAZR V3
Missing hinge pins
You will have to get a complete clasp assembly, which will have to be ordered from the factory that makes that model. If the clasp assembly is not available, A jeweler might have that part or be able to repair it for you.
Mar 06, 2008 | Field and Stream FE6BI Wrist Watch
Motorola Mobility RAZR V3 Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
