Question about Freezers
My freezer can you help me my freezer is 12 months old and it has stopped working it still runs but all my stuff was defrosting
  • librarylady2 Dec 21, 2007
    the freezer is running, the temp has been turned down, we've made sure the door is closed properly but the items on the top two shelves are defrosting--especially the top shelf. Bottom two shelves seem to be fine so far. Items in the door are also defrosting.
  • 4 Answers
Is there a temp control on this unit ?if so check the setting .if not and it is on and running but not cooling ,you have a bigger problem ,freon leak or other ,good luck
Posted on Nov 29, 2007
  • 83 Answers
Be sure your cords in the back are plugged in, and you shut the door completely, if you move the freezer to check if it's plugged in, don't pass out when you see all the lint!
Maytag MFI2269VEM2 Freezer issue. In the past two weeks, twice ice has built up in the freezer so much it is causing the fan to stop working and has been running really loud. Twice now we have taken the...
it is not defrosting. timer ,element , limit switch maybe issue. find defrost timer advance it see if compressor and fan quit running. when you advance this it should start defrost mode, which turns on the heater, which stays on till limit switch opens or timer advances, most are on 12 hour cycles
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_4ed9a6c8e57209e6
Oct 02, 2013 | Freezers
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
Freezer just stopped working
Is this a frost free freezer? If it is, and the compressor and refrigerant is good, the problem probally lies with the defrost timer. What the defrost timer does, at regular intervals, typically every 12 hours, shuts down the compressor and powers up a defrost coil to melt any frost that has built up on the cooling coils inside the freezer. It probally the small square box that you mentioned. Some have a hole where you can turn the cam to the timer and that should switch the power from the defrost coil to the compressor.
Hope this helps.
Jun 27, 2010 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Quit staying cold
TV is no problem and will have no effect...
This tip will help you see what has happened with your unit..
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Apr 22, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Ice builup on back wall of top mount whirlpool freezer
It sounds like it is not defrosting. Could be the heater, terminator, or the defrost timer. There is still ice built up behind the wall and won't take long for it to stop working again.
Jan 31, 2010 | Whirlpool Freezers
Frigidaire Ultrafreeze upright just stopped working
It sounds as if your compressor it's running. This could be a bad compressor, bad capacitor, bad thermostat. See that there are no fans or defrost, it is one of the other. I would start with checking the capacitor. You can replace it with a Supco 3 in 1. It cost around $30.00. Anything else is going to start costing $100.00 and more. If you need a freezer that big, I would have it fixed unless it ends up being the compressor.
Please rate solution
Sep 04, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
Nov 07, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Takes weeks to freeze
If you freezer has a defrost timer it should have done the defrost on its own. Only the very old freezers had to be defrosted manually. If it continues to stop cooling or you already haven't had the timer replaced or the defrost elements checked let me know.
Oct 09, 2007 | True 12 cu. ft. / 340 liter Commercial...
Freezers Logo
143 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
